Seeking Normally Closed Latching Contactor and Q&A about balancing my Li Ion battery bank
LostinSpace said:BTW - I have been talking to boB at Midnite about updating the controller to handle two inputs. Doesn't look like it's going to happen soon, but there is a solution developing using a Rasberry Pi and talking to the Classic via the Ethernet jack and MODBUS. Here is the thread if you want to have a look: http://midniteftp.com/forum/index.php?topic=3973.0. i am '5 minutes to midnite'.
So I don't know if your temperature sensor trick or the Pi would be the quickest path. Need to do something though.
What experience do you have running Linux? Do you have any experience programming computers?
I would say that now you have the battery balanced that there is not so much urgency to be able to stop the charge controller remotely.
Simon
Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
32x90Ah Winston cells 2p16s (48V), MPP Solar PIP5048MS 5kW Inverter/80A MPPT controller/60A charger, 1900W of Solar Panels
modified BMS based on TI bq769x0 cell monitors.
Homemade overall system monitoring and power management https://github.com/simat/BatteryMonitor
Even though I did an IT career (now semi-retired) I never got to deep into programming. And minimal Linux. I was making too much money fixing MS Windows. ;>
I think since my cellogs have the cell over-voltage trigger I would like to keep the electronics to a minimum and see if the Pi script being provided in the Midnite forum will work. You code requires the BMS? Won't work with the cellog output relay. How is the BMS triggering the Pi that your code is running on?
I was thinking too of putting the balancers back on. I also have to now charge and balance the other 16 cell bank, and then reconfigure back to that array you provided the diagram for.
Qty 24 Sharp 153W poly panels, Midnite MNPV6 combiner, Magnum MS-4448-PAE inverter with RC50 remote, Magnum MMP Mini panel, Midnite Classic 150 charge controller, Qty 32 LiFePO4 72AH cells in 2 string 48V array. BMS. -
Simon, one correction. The iMAX charger does indeed display AHs. The reading appears when the charge cycle is complete. Just hadn't noticed it yet with all the other telemetry on the LCD display.
The AH reading does vary a lot. These are 72AH rated cells, and the iMAX found one cell to be 83AH, and the next one to be 134AH. Of course this is not after a full discharge and charge cycle, which as noted earlier I am not attempting with these hobby chargers. I'm curious, does your charger require a full discharge/charge cycle to render an accurate AH number?
And by the way, now that I have one bank of 15 cells in good shape (still fine tuning a bit) I will be moving on to the second bank of 16 cells. I'm going to repeat was done on bank 1, but then the question of forming all 32 cells into a pack per the earlier diagram you provided.
Here's the question: When pairing up cells to be configured in parallel (2 paralled cell X 16) would you be more likely to select two cells in close voltage proximity, or might it be batter to pair cells that have the widest voltage difference?
For example take 4 cells: 3.38, 3.39, 3.41, 3.42
How would you pair those cells? Am I making sense?
Raj174 said:A reasonable analogy might be to imagine each cell as a long neck wine bottle, all with a little different capacity, all proportional in shape but varying in size ranging from 30 to 34 ounces. When charging in series, all receive almost exactly the same amount of liquid at the same rate, and as the liquid reaches the tapered neck of the smaller bottles the level will rise faster than the others. So obviously the smaller bottles will overflow first. To balance the liquid level a tube is connected between the bottles allowing flow from bottle to bottle. This is connecting them in parallel. If this is done with all the bottles full, the smaller bottles will overflow. Not good. So you really want to fill the bottles until the smallest bottle is almost full while in series, then connect them in parallel and wait for the fluid levels to even out. Once they are level, you'll want to feed one bottle slowly until the even level reaches the top of the smallest bottle and congratulations, your case of wine is now balanced.
The thing is, you have a lot of cells to monitor. And as you know the higher the voltage gets the faster it will rise. So you may get busier than a one armed wallpaper hanger.
Rick
THEORY: THE NECKS OF THE WINE BOTTLES ARE NOT ALL THE SAME VOLUME.
OK? For example, today while charging I had 3 cells that hit the 3.6v alarm threshold I had set on the cellogs. I stopped charging, and placed a bulb on each of the three cells to drop them down a bit. I stopped when their voltage was several millivolts below the other cells.
Upon turning on the charge controller again these three cells were first to go high again. In fact they shot up from about 3.4 to 3.6 FAST. just a minute or two. Maybe less.
So employing the metaphor, the wine bottles for the three cells were less full than the other bottles, yet when the 'liquid' started being poured in they very quickly filled to the neck, then to the top of the neck, nearly spilling over, while the other bottles were filled only to the neckline (or so).
I already knew capacity varies from one cell to another. But the evidence here is that charge rate -the ability of a cell to take a charge faster- (at least when near the top of the charge curve), also seems to be a variable.
I don't know if this is common among LFP cells, or perhaps just the brand I am using. But this tends to explain why the balancers can't keep up. Again, those cells went from 3.4x to 3.6x (2/10ths of volt) really fast.
Therefore, at least with these cells, an argument is made for a BMS that stops charging on a per cell basis. To justify the expense and trouble of a full blown BMS however, one would have to quantify how much additional capacity could be gained. I am tempted for now to simply back off the pack voltage a bit to keep the errant cells from shooting high.
LostinSpace said:Raj174 said:A reasonable analogy might be to imagine each cell as a long neck wine bottle, all with a little different capacity, all proportional in shape but varying in size ranging from 30 to 34 ounces. When charging in series, all receive almost exactly the same amount of liquid at the same rate, and as the liquid reaches the tapered neck of the smaller bottles the level will rise faster than the others. So obviously the smaller bottles will overflow first. To balance the liquid level a tube is connected between the bottles allowing flow from bottle to bottle. This is connecting them in parallel. If this is done with all the bottles full, the smaller bottles will overflow. Not good. So you really want to fill the bottles until the smallest bottle is almost full while in series, then connect them in parallel and wait for the fluid levels to even out. Once they are level, you'll want to feed one bottle slowly until the even level reaches the top of the smallest bottle and congratulations, your case of wine is now balanced.
Rick
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
LostinSpace said:I think since my cellogs have the cell over-voltage trigger I would like to keep the electronics to a minimum and see if the Pi script being provided in the Midnite forum will work.
I originally built my BMS around ADS1115 analog to digital converters and the Beaglebone Black microcontroller. I got the cheap BMS units for my electric push bike conversions and thought I would look at interfacing them to my BMS system. My BMS obtains the raw voltage and current data from either my ADS1115 circuit or the Bluetooth BMS and uses this. Click on the link in my signature for more information.I was thinking too of putting the balancers back on. I also have to now charge and balance the other 16 cell bank, and then reconfigure back to that array you provided the diagram for.
If you use a ring crimp connector like this connected to the battery terminal
connected to a short length of cable with a connector something like this on the other end
you can quickly and easily connect and disconnect things like the balancing boards to the battery.
Simon
LiSpace.... this is so complex |I am wondering if that is why people like PNJunction are recommending BOTTOM Balancing?
You empty them all and then fill the tank till the smallest on is full and then stop...
westbranch said:LiSpace.... this is so complex |I am wondering if that is why people like PNJunction are recommending BOTTOM Balancing?
LostinSpace said:Simon, one correction. The iMAX charger does indeed display AHs. The reading appears when the charge cycle is complete. Just hadn't noticed it yet with all the other telemetry on the LCD display.
The only way to measure a cell's capacity accurately is to discharge it to 2.5V then charge it up to 3.6V with a termination current of less than C/50 and measure the Ah needed to charge the battery.And by the way, now that I have one bank of 15 cells in good shape (still fine tuning a bit) I will be moving on to the second bank of 16 cells. I'm going to repeat was done on bank 1, but then the question of forming all 32 cells into a pack per the earlier diagram you provided.
You can't use voltage to pair the cells. You can only use capacity obtained by doing a capacity test.
If I were in your situation I would discharge your battery connected to the Midnite by about 20%SOC. Then reduce the charge voltage on the Midnite to 3.4V/cell (54.4V) and float to 3.3V/cell. Then do a normal charge with the Midnite and make sure all the cells are balanced at the 3.4V charge voltage. Charge all the other cells to 3.4V with the IMAX. Then disassemble the battery connected to the Midnite and put all the cells from this battery and all the separate cell in parallel and charge all the paralleled cells to 3.6V using the iMAX. Ideally you would want to leave the cells charging at 3.6V until the charge current reduces to around zero and then leave the cells on charge at 3.6V for another ten hours or so but it doesn't look like you can do this with the iMAX. I couldn't find any information on what conditions cause the iMAX to terminate the charge. This being the case doing a Balance Charge at 3.6V will have to suffice.
Simon
westbranch Interesting, I have more entries from PNJunction posts in my LPF notebook prior to purchasing, than any other member. Very high credibility.
karrak said:
This doesn't make any sense. 83Ah is just plausible, 134Ah makes no sense. Is the iMAX summing the charge from multiple charge cycles?
So obviously I am clearing the last status by hitting the STOP button in between cells, but the charger is holding the cumulative total in memory. Good call.
But let me play this back to you: The final step in your scenario is to charge all 32 paralled cells to 3.6... then wait for charge current to drop to near zero.... then continue for about another 10 hours?
The gold standard for balancing cells is charge them all in parallel to 3.6V-3.65V, wait for the current to drop to nearly zero and then charge for another ten hours or so.
Since the iMAX charge current is so low, in your case C/384, just charging them to 3.6Vwith the iMAX until it terminates the charge will do a good job. Might take a few days though.
I don't think I can get my Turnigy 300W to charge the extra ten hours but I can get it to keep charging until the current gets to nearly zero. If I was going to balance the cells in parallel I would use my 20A bench power supply after charging the cells in series to ~3.4V/cell with the Turnigy to save time.
Simon
I am going to give the 'gold standard' a try with the iMax charger. Will report findings.
karrak said:The gold standard for balancing cells is charge them all in parallel to 3.6V-3.65V, wait for the current to drop to nearly zero and then charge for another ten hours or so.
mike95490 said:karrak said:The gold standard for balancing cells is charge them all in parallel to 3.6V-3.65V, wait for the current to drop to nearly zero and then charge for another ten hours or so.
In Jim's case he has 32x72Ah batteries. If they are charged in parallel this equates to 2304Ah, charging from 0% SOC at 6A would take 384 hours (16 days). New LFP batteries when purchased are usually at an SOC of ~50% so would take ~8 days to charge. If you charged the cells to 3.4V/cell in series which would take the SOC to > 90% SOC then did the final balance charge it would take less than two days.
Simon
And that is what I have started on (as of yesterday). The 32 cells are all configured in parallel. I am letting them sit that way for 48 hours to rest and equalize. Charged both banks first to ~3.41x volts to give them a head start.
DAY 0: Have now started charging the pack. Pack voltage 3.327v.
Awesome! It's going to take quite a while at 5 amps, but patients will be rewarded.
end of Day 3 = 3.340
zzzzzzzz....
Note: The charger did turn off on day 1 for an unknown time. I had disabled the Max Charge Time timer, but not the Capacity Cut-off timer, which was set at the maximum setting of 50,000mAH (50 AH).
Thankfully I don't need to have my system powered on for critical items like Satellite internet. Nor less-critical items like refrigeration, heat, and lights.
Yep, this is why it is important to get as many amp hours pumped into the bank with the initial series charge as possible. It reduces the time charging in parallel. When I balanced my 195AH cells with a 10 amp charger, it took about 10 hours in this phase. Of course, it was a rebalance so cells were closer to start with.
Day 7. Sick in bed for 3 days straight. Upon checking on Day 7 found that the charger had completed the cycle.
The hr timer only seems to go to two digits so the total time calculates as 114 hours, or nearly 5 days. And of course some hours were lost day 1 when the charger turned itself off.
So not too bad, really. So now I am going to disconnect the parallel rigging. Not sure whether to then let them sit for a couple of days and see what individual voltages settle down to, or just reconfigure into a 144AH array and start cycling.
Sorry to hear about you being sick. I was beginning to wonder if I had miscalculated something. Thanks for the update.
I wouldn't worry about waiting for a few days.
When you start cycling I would start with a charge voltage of 3.4V/cell (54.4V) and end current of C/50 or absorb time of 1/2 an hour and see what the balance is at the end of charge and work up to 3.45V/cell (55.2V).
Simon
Check.
OK. System is online and looking happy. I indulged myself by waiting for 24 hours after removing the parallel bus bars from the array. I wanted to see what cell voltages would do after resting for a day. Today I saw something I had not yet seen since purchasing the system. All cell voltages remained in the 3.5.x range. See photos
Every other time I have checked the cells when I charged them as a PACK to the 3.6 the cells fell back to the high 3.3x range up to the 3.4.x range.
But they have never held their charge like they did this time after charging in a parallel config with a 3 volt LFP charger.
There's only one possible explanation. The cells have never been truly charged since I bought them.
I also took photos of cell voltages right after turning on the inverter and loading the array down with the load from my freezer. Was happy to see that although voltage of course dropped, the cell voltages are staying pretty close.
Pretty good. Pretty, pretty good. (That's my Larry David imitation).
Before connecting to inverter
Inverter ON
@LostinSpace
Great job! That's just what it should be. Really takes time and patients. You have a nice high balance, so an absorb setting equivalent to 3.45 volts per cell should work well.
Thanks for the continued updates.
Thanks Rick. Sure have appreciated your input.
For "scientific" purposes I am going to post a bit more on this just in case someone happens along. I want to take some readings near the discharged state, then read cell voltages again when charged to 3.4v, and see how well the pack is staying balanced. I will likely post on pack balance now and then for informational purposes.
I say 3.4, because the scenario here is that this is primarily a standby system for the time being. We have grid power. But I don't want to simply set cell voltages at the storage voltage and turn the system OFF until needed, because in my experience all things atrophy from disuse. ;>
So I will continue to run my ~350w stand up freezer, and find a sweet spot where I can charge the pack enough to run the freezer yet maximize cell life (open to suggestions). I will say that during the winter, with only 6 panels mounted so far, on cloudy/stormy days the system may draw close to the full range of the charge. But with the pack properly charged now I will take a fresh look at how much standby time is needed.
I have the inverter set to turn off at 48v (3.0v). That should not be anywhere near where degradation might occur. It's weird because the specs for these particular cells specifies minimum voltage at 2.0. But from everything I've read that is dangerville.
I see, so after running all your tests at higher absorb settings, around 3.4 volts, it might be interesting to test absorb slightly above 3.35 (float) setting. This in my opinion, would be less stress on the cells, and I think the freezer wouldn't be too heavy a load that the bank wouldn't cycle well. The SOC would likely stay between 75 and 90%. A lot of experimentation possible.
I agree, low voltage cut out at 3 volts per cell is fine. I'm sure you will be monitoring the balance at that time and I am interested in the results as well as the SOC.
Rick
OK. I just did a full cycling of the pack and here are some numbers:
DISCHARGE
One hour into discharging cell voltages were 27mv apart (3.324 - 3.351)
Three days (60hrs) into the discharge cycle cell voltages were 14mv apart (3.169 - 3.183)
The inverter is set to turn off at 48.0v (3.0v) At that event cell voltages were 202mv apart (2.872 - 3.074)
CHARGE
Upon recharging to 54.4v (3.4v) cell voltages were 171mv apart (3.352 - 3.523)
Only one cell was particularly high at 3.523. if that cell was dropped from the averages the range would have been 3.352-3.465) or 113mv.
I'm wondering if perhaps setting the cutoff voltage such that no one cell dropped below 3.0 might yield better results for keeping the pack balanced.
I am surprised that you are getting such a variation in cell voltages after the balance.
Discharging the battery so far, the fact the cells are new and might not have had enough SEI forming cycles at the factory might all be factors.
I think it is better for the battery to have more little charge/discharge cycles rather than fewer large cycles. With your current setup I would let the solar controller charge the battery each day and have the loads discharge it at night.
For battery life if you are not concerned about running out of power due to cloudy weather it is better to cycle it between ~30%-~75%. I would look at the last 20% of charge (0%-20%SOC) as an emergency reserve and only go there occasionally. I doubt our battery goes below 25% more than ten times a year.
I would put your balancing boards back on. Hopefully your battery will become more stable after a few cycles.
Do you have the Wizzbang Jr. working so you have an SOC meter?
Simon
karrak said:I would look at the last 20% of charge (0%-20%SOC) as an emergency reserve and only go there occasionally. I doubt our battery goes below 25% more than ten times a year.
Simon I want to put a voltage number to those percentages if you don't mind. Are you defining 0% charge as 3.0 volts?
If so, are we calling 3.45v 100% charge, and 3.0 volts 0%?
Thus 3.23 would be 50% discharged.
Thus 80% discharge would be 3.09v (or rounded to 3.1v).
- 626 Discussion Forums/Café
