Tiles Or Concrete?
pedro12pedro12 Posts: 2Registered Users
Hi all, i want to ask which type of flooring is best in terms of reliability and durability, i want to redesign floor of my house.
  • lzhomelzhome Posts: 38Registered Users ✭✭
    Both will still be in place when we are all gone. The question is how do you want the floor to look? Tile offers more options.
    TriStar MPPT, 8 x 100w PV, MNPV6 Combiner, 4 x 12v 155ah VMAXTanks AGMs and GoPower 2000w PSW Inverter.
  • EstragonEstragon Posts: 2,331Registered Users ✭✭✭✭
    Both *could* be in place when we're all gone, but only with proper substrate, prep, material, and installation. I've seen both fail in short order.
  • Dave AngeliniDave Angelini Posts: 3,703Solar Expert ✭✭✭✭
    Stay away from solar tiles :)
    "we go where power lines don't" Sierra Mountains near Mariposa/Yosemite CA
     http://members.sti.net/offgridsolar/
    E-mail [email protected]
  • BB.BB. Posts: 27,446Super Moderators admin
    Over the years, I have seen that the subfloor is critical to any installation. Week subfloor (or 400+ lb tenant) and almost no standard flooring will last.
    I have used Pergo type flooring for some apartments and homes (ongoing maintenance). The flooring is easy to install and holds up pretty well--HOWEVER, if you have any water issues (leaks, kids spilling drink, etc.), the water gets in between the grooves and swells up the "particle board". It does not with-sand water at all (the surface is Formica like--which does ok with water).
    I am still of mixed thinking about if I will use Pergo type flooring again. Just regular tongue and groove wood floor+finish is more forgiving (in general regarding water--The finish varnish is not that hard for high traffic areas). Plus it can be refinished.
    Tile--There is always the issue with grout lines--They get dirty and crack. The tile itself does hold up well (also various natural stone can do OK--Keep marble tile away from wet areas, such as around the bathroom and kitchen).
