New Samsung Battery Showcased: 20% Shoter, 50% Higher Capacity Than 18650 Battery
Qes
Registered Users Posts: 5 ✭
Hey people,
Check out this new article that popped up.
Samsung shows new battery back based on modules.
Link here:
https://futurism.com/samsungs-new-electric-car-batteries-boost-range-to-600-kilometers/
Second link (you can find in the first article but is more detailed):
"Samsung SDI also displayed cells and modules based on the new 21700 standard of cylindrical battery. A ‘21700’ battery is 21 millimeters in diameter and 70 millimeters in height. Its capacity is 50 percent bigger than the existing 18650 battery (18 millimeters in diameter and 65 millimeters in height). Its size is optimal for maximizing capacity, life and output simultaneously. The new battery beats batteries of any other size in light of cost competitiveness. A 21700 battery draws attention from major global manufacturers as the next-generation standard which can be applied to all sorts of products including electric vehicles, ESS and electric tools."
So it is 3mm bigger in diameter, and 15mm taller. How is that shorter? (Assuming "Shoter" was a typo, otherwise I don't know what it means)
So the volume of a 18650 cell is 66,162 cubic mm (pi * 18 * 18 * 65), and the volume of a 21700 cell is 96,981 cubic mm (pi * 21 * 21 * 70). That's about 47% more volume, so yeah, it is about 50% more capacity. Doesn't seem like a breakthrough to me.Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 8S (25.6V), 230Ah Eve LiFePO4 battery in a custom insulated and heated case. -
Yep. advancements are accelerating with new, bigger-better products emerging.
My approach is to see how it shakes out before investing my customer's money. I prefer to let other folks test the "bleeding edge" of technology for me. (Been-there-done-that, have the T shirt)
There is a whole lot of good stuff coming very soon.
Marc
This was originally announced in January 2017.
Samsung has yet to begin mass production <= yawn.
Telsa is already mass producing the 21700 cell ( since June ? )
18650 cell = 250 KWH / kg
21700 cell = 300 KWH / kg
The 21700 cells do have a higher Energy Density,
they contain 20% more energy per the same weight.
Tesla says,
The only real difference between the 18650 and 21700 is increased size for more active material.
40% more active material per kg = 40% more capacity per kg
There is the old rule of thumb with math... When you have a 3 dimensional object, the volume goes up with the cube of the dimensions, and the surface area (outside of the battery) goes up with the square... I.e. a 20% "longer/larger diameter battery" would:
- 1.2 * 1.2 = 1.44 more surface area (case)
- 1.2 * 1.2 * 1.2 = 1.728 more volume (active material)
Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset - 1.2 * 1.2 = 1.44 more surface area (case)
Lithium technology presents a winning argument when weight is a large consideration. Other than size, weight, charge characteristics, and longevity....I still believe in lead for most solar applications. Lithium is darned expensive and life tends to realize significant changes within 15 years. Such as moves...
Sometimes they juice up the specific gravity and call it a high performance battery sold for more money. Since that decreases the longevity, it is misleading in some ways.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
BB. said:There is the old rule of thumb with math... When you have a 3 dimensional object, the volume goes up with the cube of the dimensions, and the surface area (outside of the battery) goes up with the square... I.e. a 20% "longer/larger diameter battery" would:
( He incorrectly used "diameter squared" vs "radius squared" but for the ratio of the volumes, it does not matter )
The 21700 cell is 1.47 times larger volume, not 1.728 larger as you claim, vs the 18650 cell - which relates to mAH capacity.
They increased the battery volume by ~47% ( not ~73% ) and so 21700 has roughly 50% more mAH capacity vs 18650.
In my message #4, I discussed Energy Density ( mAH per kg ) - not mAH capacity.
They have also increased the Energy Density by 20% - ie now weighs less per same mAH capacity
I am very concerned with both weight and volume.
A 48 Volt 17 KWhr Lead Acid Battery Bank 30% DOD 7 year ( if you are lucky ) system consisting of ...
24 @ Trojan L16RE-2V batteries = 16' long shelf and it weighs 2,800 lbs !
$9,360 = $390 x 24 batteries
Now add $ for a 48 Volt 100 Amp 3-Stage Charge Controller, with EQ mode
Now add $ for a 5KW DC-to-AC Inverter
And you have to maintain the electrolyte every month for life, otherwise they will fail early.
You are "married" to this battery bank - hydrometer readings, EQ cycles, distilled water, etc ...
The Power Wall 2 is 14 KWHr, 2' W x 4' H x 6" D wall hung, 276 lbs with a 8 - 10 year guarantee
$8,000 - includes AC Inverter and DC Charge Controller
Someone needs to find a mistake in the above information,
otherwise I see no advantage using Lead Acid Batteries vs Lithium Batteries.
I was not saying that the battery was 1.7xxx larger volume in this case... I was just trying to demonstrate how surface area increases with the square of the dimensions, and volume with the cube with random numbers--So things become "more volumetricly efficient" the larger they are (same type of issue with small bar refrigerators vs full size refrigerators become, overall, more efficient the larger they are).
From Wikipedia:
Energy density is the amount of energy stored in a given system or region of space per unit volume. Colloquially it may also be used for energy per unit mass, though the accurate term for this is specific energy.
Elon Musk was speaking colloquially ...
So far, I'm staying in the "most" category.Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers
- 628 Discussion Forums/Café
