drich5 - Batt. bank fuse sizing
drich5drich5 Posts: 7Registered Users ✭✭
I have 8 155ah batt. connected in parallel, for a 1240ah total.  What size fuse do I need for adequate protection?  What size wire do I need for charge/load wiring?  What size wire do I need for batt. interconnect wiring?  This is a 12v batt. bank.
  • mike95490mike95490 Posts: 7,916Solar Expert ✭✭✭✭
    edited February 2017 #2
    There are not enough fuses to make 8 parallel batteries safe,     Sorry to be blunt.
    Fuses protect wires.   Wires are rated by the amps they can safely carry,  So the wire size controls the fuse size
    12 ga  20A
    10 ga  30A
      6 ga 55A
    and so on, there are NEC ampacity tables that list the ratings for wires.
  • drich5drich5 Posts: 7Registered Users ✭✭
    Of course, you are right. Thanks for the reminder.
  • littleharbor2littleharbor2 Posts: 1,035Solar Expert ✭✭✭✭
    If you NEED that much power with a 12 volt bank you should consider 1110 Ah 2 volt batteries.
    https://www.solar-electric.com/trl111ah2dec.html
    2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old  but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
