NEED Extruded ABS Sheeting for reasonable price!
SolarPowered
Solar Expert Posts: 626 ✭✭✭
So I need a face plate for my generator to mount the ameters, 12V ports and some switches.
Interstate plastics looked reasonable at first 2'X2'X.25" sheet was $15....... Then they wanted an additional $15.00 for processing.....SERIOUSLY? Then shipping $13.42.......For an item that weighs under 2LB.s?
TAP plastics I have locally and can go to their store however no ABS sheets are available and am told I have to order....... Total is $36.00
I am seriously feeling a little disparaged, and kicked around as a consumer, the only reason these companies jack the price on "RECYCLED" ABS is because I can't find a resource to get it any where else.
So does any one have a good place where I can just get a recycled sheet of extruded ABS 2'X2' and atleast a 1/4" thick?
Re: NEED Extruded ABS Sheeting for reasonable price!
Try plexiglass from the local hardware/building supply. -
http://www.ebay.com/itm/24-x24-X-1-4-BLACK-ABS-PLASTIC-VACUUM-FORMING-SHEET-TEXTURED-FRONT-SMOOTH-BACK-/281093915348?pt=US_Car_Audio_Video_Dashboard_Installation_Kits&hash=item417280c2d4
24 X 24 X 1/4 Black ABS $14.90 + $17.10 shipping. -
If no luck. U can try fiber glassing your own panel
Fiber glass is electric proof and weather resistant? -
I got mine through Amazon at a reasonable price. With the Amazon Prime, I got 2 day shipping for free. -
I will look into amazon since I am a prime member. Tried looking the other day and couldn't find a sheet in 1/4" thick.
I prefer ABS (extruded or machined) for its tolerance to heat, and because its easy to machine and clean up the corners, it also matches my black box, and meters. -
http://www.amazon.com/ABS-Plastic-Sheet-Thick-Thickness/dp/B0072JYLXE/ref=sr_1_1?ie=UTF8&qid=1376871203&sr=8-1&keywords=abs+plastic+sheet
They have bigger sizes but the price jumps pretty quick. -
Re: NEED Extruded ABS Sheeting for reasonable price!http://www.amazon.com/ABS-Plastic-Sheet-Thick-Thickness/dp/B0072JYLXE/ref=sr_1_1?ie=UTF8&qid=1376871203&sr=8-1&keywords=abs+plastic+sheet
Yeah I just bought it from them in the 1/8" thick sheet. I think I will do fine with it.
$21.80 free shipping. Gotta love being a prime member! Beats Ebay all day long!
- 628 Discussion Forums/Café
