Dow Solar Shingles Hit The Market
RSSfeed
Registered Users Posts: 3,810 ✭✭
* After encouraging trials with roofing contractors in Texas, California and Colarado, Dow Chemical’s building integrated solar PV*is hitting the market. Dow’s Powerhouse Shingle integrates thin-film CIGS photovoltaic cells right into*standard asphalt shingles.*Roofing contractors install the shingles with no specialized*skills or knowledge of solar*installation*required. The product design is said to reduce installation costs...
go to solarfeeds for the rest of this story>>>>>
More...
More...
Re: Dow Solar Shingles Hit The Market
Following the Dow link to more info, we find out that this results from installing a GTI: We always knew it took a special meter for net-metering. :-)
No clear indication how you deal with roof penetrations which would disturb the continuous rows of the shingle array. I am sure they have a way, but their illustrations show nice clean roofs.SMA SB 3000, old BP panels. -
I remember first hearing about this type of solar panel some 20+ years ago. Had the same problems then too. -
The thing to worry about is all those shingle to shingle connections. This has been the problem in the past. Plus, don't expect this to be a cost-competitive solution with Crystaline PV. For roofs that need new shingles and are in a oppressive HOA regime, might be a good way to go.
Were can I buy some of those I Luv Solar meters?
- 218 Forum & Website
- 185 Solar Information links & sources, event announcements
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 600 Discussion Forums/Café
- 298 In the Weeds--Member's Choice
- 73 Construction
