MC-4 crimp tool
paulskirocks
Solar Expert Posts: 84 ✭✭✭✭
OK, I have seen the custom MC-4 crimp tools for a few hundred dollars, but is there a cheapy out there that will actually crimp it correctly?
Re: MC-4 crimp tool
One option if you will only need to make a few crimps--Purchase some male/female MC4 cables and cut them in 1/2. Splice them into the rest of your system.
Re: MC-4 crimp tool
Well, I already have the separate wire and connectors... There are only four to do, but I still want a good connection... What about soldering them? They are just 8 amp strings... -
Re: MC-4 crimp tool
Here is one thread with a less expensive crimping tool (something like $30-$45 each???):
What is the fastest way to add MC4 connectors to final return lines on GT solar array?
I have soldered many connections over the years--If the cables are well supported (so they cannot flex), solder can work OK. If the wire flexes, the solder forms a fulcrum where the flexing is focused and the copper work hardens/fails. Make sure you use rosin core or "no clean" solder made for electrical soldering--not plumber's flux (which is corrosive).
It has been subject of several threads here with lots of strong opinions... From a UL point of view, soldering is not a "safe" connection if the joint melts and the wire pulls out of the connector.
And a proper crimp connection is gas tight anyway--so solder does not add anything (IMHO) to the quality of the joint.
Re: MC-4 crimp tool
I just had the same situation where I had a just few to crimp. I bought some generic crimping tool ( was on the end of a wire cutter). Then what I did was take a (** small **) needle nose pliers ( even that medical needle nose thing is good) and bent the little ends (from the mc4 connector) around the wire. after they were "kind of" around the wire, I squeezed it hard the the generic crimper. Then, just for my piece of mind, I through a little solder in there. Worked just fine and didn't have to spend as much on a crimper that would have to spend on a panel. -
Re: MC-4 crimp tool
OK, thanks for that link... I just ordered the Eclipse 300-176 for $45 shipped... I can see where this crimper will com in handy for other connectors, as well...
http://zackelectronics.com/tools-installation-aids/tools/crimpers/eclipse-300-176-tools-crimpro-crimper-for-mc4-solar-panel-contacts.html -
Re: MC-4 crimp tool
It will also work on Anderson connectors. Hope it is the ratcheting type...
- 218 Forum & Website
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 599 Discussion Forums/Café
- 73 Construction
