Looking for best offgrid refigerator -- and not a converted chest freezer
PorkChopsMmm
Solar Expert Posts: 189 ✭✭✭✭✭
We are completing the inside of our offgrid cabin and we realized this past weekend that the converted chest freezer as a refrigerator, using an external electric thermometer, will not fit in our space. Because we want both a fridge and a freezer having two chest freezers in our kitchen, or really even one chest freezer, would take up too much space. We are thinking we need to switch our game plan to a vertical fridge/freezer combo. I am avoiding paying ~$2700 or so...I would rather put the money into additional solar and batteries.
What do you all use for refrigerators? I found this one from Fridgidaire using the energy star website. It uses 355 KWH a year and costs $365. It is 14.8 Cu feet... which is the largest I have seen with the lowest energy rating. A SunFrost RF16, which is roughly the same size, uses 254 KWH a year but costs near $3k with shipping.
Linked here.
What would you all go with?
Linked here.
Re: Looking for best offgrid refigerator -- and not a converted chest freezer
Well, we have the Sunfrost DC units. We have a 'fridge, a small one of 10 cu. ft. that has a small freezer compartment inside at the top [that size combo no longer made, I think]. We also have a 10 cu. ft. freezer.
Both are great, I think. They are, as you mentioned, pricey. When we bought the 'fridge, way back in the 80s, they were one of the few brands suited for offgrid DC appliances of the type. Now there are good things being said about "normal" fridges and freezers as to their efficiency, though I have had no experience with them. A neighbor of mine opted for one of these, I don't recall the brand but it does not matter as this was ten years ago, and no doubt there are even better ones now that would work for you. I do not have any numbers for his electrical use, etc., though his is, of course, a 120-volt model and runs via inverter off his 24 v. PV system. He is happy with it is all I can say.
The Sunfrost 'fridge we have has been running since the 80s, as I said, and we've had no problems with it other than the door catch needing replacement twice. Both times, they sent me new catches [no charge] and now they've begun using a very good magnetic catch system, which our 3-yr. old freezer has and it is great. The magnetic catch is not visible, and I cannot imagine it could go bad. The Sunfrost stuff is a lot of money, though in our experience it is very long lasting and reliable. -
Had several experiences with Frigidaire lately... Basically did not last more than a few years.
I've got an 18cf Fridigare, 2 years old, and OK. Not much more power than yours.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I certainly would not be happy with something that only lasted a few years. However in this case with such a price difference and the local availability, if it died in 3 years you could then buy an even more efficient unit and still be $2300 ahead (excluding the cost to enlarge your system slightly to cover the additional 100 kwh load).4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Re: Looking for best offgrid refigerator -- and not a converted chest freezerHad several experiences with Frigidaire lately... Basically did not last more than a few years.
I too have read some bad reviews of Frigidaire. There are other types of fridges in this size with similar power ratings.I certainly would not be happy with something that only lasted a few years. However in this case with such a price difference and the local availability, if it died in 3 years you could then buy an even more efficient unit and still be $2300 ahead (excluding the cost to enlarge your system slightly to cover the additional 100 kwh load).
How much do these eat per day? I am wondering if this is on par with my Biolet composting toilet or if this is on a whole new level of power usage. -
Well, there goes any ideas I had of trying a Frigidaire mini-split! Sanyo mini-split not available here. -
My experience was with Frigidaire refrigerators. I have no idea how this would apply to their other products.
Re: Looking for best offgrid refigerator -- and not a converted chest freezerwaynefromnscanada wrote: »Well, there goes any ideas I had of trying a Frigidaire mini-split! Sanyo mini-split not available here.
Several different mini split systems around based on inverter technology, mine are friedrich.
http://www.friedrich.com/products/commercial/ductless-split-systems -
The repairman that I have used for a couple of decades says the only fridge built to last is Whirlpool. -
Re: Looking for best offgrid refigerator -- and not a converted chest freezerThe repairman that I have used for a couple of decades says the only fridge built to last is Whirlpool.
There are Whirlpool ones with near identical specs, although they are harder to find that the Frigidaire ones, at least near me, in stock. Looks like it is a wash.
Here are some values from Energy Star:
Whirlpool
W5TXDWFX*0*
14.64
Top Freezer
No
354
443
20%
I am starting to think I should go with one of these, buy new batteries and if money is left over look for a few additional panels. -
You might look at sears. They have refrigerators that are made by whirlpool. Sometimes you can catch a good sale. When I needed a fridge in an emergency about 4 years ago I went to lowes and looked at a whirlpool and went to Sears and got the identical kenmore model about $175.00 less. :Dsolarvic:D -
Bought a Whirlpool refer/top freezer in 2005 for the off-grid cabin. Uses less than 1 Kwh/day. So far so good ... no problems yet.
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Got a Samsung 2.5 energy star using 339 kw per year around $550 nz dollar on special. Working great and i have checked it with a watt meter and it would seem the rated spec to correct..
Leaves money for more pv!2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
Hi,
We just purchased a Samsung 17.8 cu.ft. french door fridge with freezer on the bottom. The first 24 hour period running the kilowatt meter, it pulled .9 kw. The starting surge is around 300 watts. This fridge has 2 seperate compressors; one for the freezer and one for the fridge portion. When cycling, starts out around 110watts and drops down into the 80 watts or so. We are so far, extremely pleased with it's performance. We wanted to go with a conventional fridge. This one has LED lights in both fridge and freezer. A really nice unit. This is the smallest french door unit that Samsung makes. This replaced an 11 year old Frigidaire that pulled almost 1.9 kw per day. -
the first 24hrs it will run nearly constant to reach operating temperatures so a new reading is in order to show what it's doing under normal everyday conditions. .9kwh (if that's what you meant) is quite good even under normal conditions.
1.9kwh (again if that's what you meant) per day is terrible and is even worse than my 14yr 21cf old roper/whirlpool. -
Thanks for all of the feedback. A fridge in this size/price/efficiency range looks like it is the way to go. Thank you for the help! -
The .9KWH was taken on the second day that the fridge was up and running, and yes the old pulled 1.9KWH!!! I was soooooo- happy to unplug it! We're still small for now so it's still a balancing act with the loads/battery bank, but we're heading in the right direction.:D -
I think your on the right page with such miserly energy use the regular (non propane non converted freezer) fridge is the way to go. Mine is a Kenmore and it uses about the same as the one your looking at.
Once it's full and all items inside are cool it will run much less. The ambient temperature has a lot to do with it also, mine hardly runs in the winter but in the summers It kicks on a lot. -
My RV, propane refrigerator works outstandingly well on very little propane... so for energy conservations sake propane can be a very good choice.
Also note most propane refrigerators can run on both propane and electric power and switch energy sources automatically. This provides a degree of backup over using solar alone. -
Re: Looking for best offgrid refigerator -- and not a converted chest freezerMy RV, propane refrigerator works outstandingly well on very little propane... so for energy conservations sake propane can be a very good choice.
"Very little propane" would be good, but our's weren't that frugal.
We lived with propane refrigerators for many years (two RV models installed side-by-side in our kitchen). They were ok, much better than the propane Siber they replaced which we could best describe as "luke-cold").
However, propane prices have risen dramatically this last decade. I guesstimated that the fridges were costing $50/month in propane. That would be about 9 gallons per month each at $2.65/gallon, which I think is a reasonable estimate. I've seen it said that a 6 or 8 cu ft propane fridge should use about 2 gallons of propane per week.
That I had to pull them out twice a year to clean the burners was ok. No icemaker, still ok. Having to manually defrost them both a couple of time per year was still allright. 12 cu ft via two fridges, still ok. $50 per month, not ok.
I'd figured on eventually having enough solar that I could power the fridges on electric and only rely on propane during the "no sun" days. That was until Dometic started acknowledging problems and initiating recalls when their units were used on electricity. I started visualizing my home burnt to the ground because of Dometic's design deficiencies. (details in this forum's thread: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/18592867.cfm)
And even using them on electric meant there was a heater in each unit and most members here will confirm that heating anything with solar electric isn't efficient.
We added some more solar panels with a controller and installed an electric fridge. I then had more accurate data and learned we'd been spending almost $75/mo on propane for the two refrigerators. (Yeah, some of which was due to my lax defrost schedules).
I've no complaints about the past. When we first started using propane to refrigerate our foods, regular friges weren't very efficient. Thankfully, that has changed.
Propane refrigeration is great for a weekend cabin or an RV but for full time use, I believe a new electric is better.
Phil -
Thanks for the advice. I think I am going to go with an energy star fridge in the 14 cu ft size or so straight from Lowes. The price is good and the delivery will be free. While I am at it, I think I am going to get an energy star washer and gas/propane dryer to boot. -
I to hope to be off the propane soon. With cooking and refrigerator We spend $ 60. A month.
ThomOff grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat -
Re: Looking for best offgrid refrigerator -- and not a converted chest freezerPorkChopsMmm wrote: »Thanks for the advice. I think I am going to go with an energy star fridge in the 14 cu ft size or so straight from Lowes. The price is good and the delivery will be free. While I am at it, I think I am going to get an energy star washer and gas/propane dryer to boot.
You've already done some checking, but a few years ago there wasn't much difference in energy usage between a 14cf and an 18cf. There also wasn't alot of difference on the price. We got the 18. Jumping up to the 21 meant quite a bit more money and more power usage.
I did opt for nothing delivered "through the door" (ice or water) because enough people had posted on the decreased energy efficiency of those models.
I even opted for the extended warranty (a rarity for me!) so that IF something happened, Sears would not only come all the way out to our rural home in a timely manner, but either fix it or replace it at no charge.
Phil -
Re: Looking for best offgrid refrigerator -- and not a converted chest freezerYou've already done some checking, but a few years ago there wasn't much difference in energy usage between a 14cf and an 18cf. There also wasn't alot of difference on the price. We got the 18. Jumping up to the 21 meant quite a bit more money and more power usage.
Phil
Good point. I need to show my wife an 18 cu footer and see what she thinks. We have rented and lived in a big city for so long that we are used to smaller appliances. I will show her both and get her opinion. -
I got some firm #'s last week with my Eng. Star Fridgare - I'll post later tonight, right about 1KWh per day, 18cf top freezer.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Looking for best offgrid refigerator -- and not a converted chest freezerI got some firm #'s last week with my Eng. Star Fridgare - I'll post later tonight, right about 1KWh per day, 18cf top freezer.
Great, thank you. I visited Lowe's with my wife and she prefers the 18 cu ft size. Whirlpool has a Tier 3 Energy Start fridge for ~$600 -- looks like that will be what I go with.
http://www.lowes.com/pd_355480-46-WRT3L9SZYW_4294789497+4294867585+4294791478_116_?productId=3436404&Ns=p_product_price|0&pl=1¤tURL=%2Fpl_CEE%2BTier%2BIII_4294789497%2B4294867585%2B4294791478_116_%3FVa%3Dtrue%26Ns%3Dp_product_price|0&facetInfo=CEE%20Tier%20III|Yes
I have basically that same fridge. I have had it plugged into the kill o watt for about a week and it averages .96kwh per day. It has been using less power the last few days because the temps have been dropping and I refuse to use any heat in my house. -
Re: Looking for best offgrid refigerator -- and not a converted chest freezeroffgrid me wrote: »I have basically that same fridge. I have had it plugged into the kill o watt for about a week and it averages .96kwh per day. It has been using less power the last few days because the temps have been dropping and I refuse to use any heat in my house.
Great to hear! Thank you for confirming. -
I found the scrap of paper with my K-A-watt #'s on it:
18 cf Frigidaire top freezer, 125 hours, 4.36Kwh which I think works out
to .838KWh daily, with 88F daytime temps,
and average use, with cooling about 1 gallon of water bottles a day, and many openings daily to retrieve them. Pics later.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
FYI Lowes has their fridges on sale for 10% off (ends tomorrow night). If anyone is looking for one, now would be a good time.
If anyone does want to buy one, I can email you a 10% off coupon as well..... every little bit helps.....
I just bought:
http://www.lowes.com/ProductDisplay?langId=-1&storeId=10151&catalogId=10051&fromStore=true&partNumber=8899-2251-LFFN15M5HW
$363.69 + tax.
That will replace the power hog Roper Fridge/Freezer in the garage (dont even use the fridge part...). So I will have about 2x the storage space and use 1/2 the power.
Shane
- 628 Discussion Forums/Café
