old jacobs
ws9876
Solar Expert Posts: 440 ✭✭✭
do you think it would be worth rebuilding an old Jacobs alternator if you could find one???
I have seen an old full unit next to the hwy....its very old...wooden blades....
Re: old jacobs
Just the alternator, or the entire powerhead ? new blades are the easy part, if it's really the old original style, I'd grab it. Where did you say it is ??Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: old jacobs
way up north here... are they pma or other..?? -
Re: old jacobsway up north here... are they pma or other..??
The old ones, are way before PMA's - 40's I think, speed governed by vari-pitch prop, complex. but effective.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: old jacobs
The old Jacobs are classics and one of the best turbines made in the 1930s & 1940s.
Here is a bit of historical reference from their website: http://www.jacobswind.net/history/original-company
I'd love to have one of their freezers. Holding a temperature for days without power is something I haven't seen any modern off the grid refrigeration systems do. -
Re: old jacobs
What a great piece of video with Jacobs at the fair........ -
Re: old jacobs
The original Jacobs were direct drive DC generators, not alternators, and are worth restoring. The later ones used a gearbox driven alternator, and if gotten cheap can be worthwhile also, as the same later style machine is still available new.
My old 1940s vintage Jacobs (2500 watt, 32 volt) has been working for us since 1977 or so.
Jim
- 628 Discussion Forums/Café
