Reset amp hours question
pfisher
Registered Users Posts: 7 ✭
Hi, my mom has a trimetric dealy (tells amp hours, volts, etc.), and a trace engineering dealy (controls the float and bulk charging stuff, I think). Her amp hour readings on the trimetric have gotten more and more out of whack. From what I read on this site, it should automatically reset itself when the batteries become full. I think it's had repeated partial charging which caused the amp hours readings to drift. I'm trying to fully charge it with the generator (not enough sun) and see if that's correct. I just turned the generator off and back on to put in more gas, and the trace engineering thing was on float before, but now it's back on bulk. Any ideas on how long it should take to fully charge it? If it's close to full but not fully full, can I just reset it and at least be back to close to accurate? Thanks.
Re: Reset amp hours question
that meter does need other factors programmed into it such as its efficiency at charging and many people can really only take a good guess at that. this means over time that even the best guess would eventually show the compounding of errors. this also does not account for battery aging or any other influences that could change the battery characteristics.
my advice is start over with the meter by resetting it. -
My worry is that, say it's at 90% full, because I can't tell what's full anymore after the numbers have drifted so much. If I reset it, and tell it that that's the new full, will it then allow the batteries to go below 50%, which is supposed to be their current cutoff, I guess. It's supposed to be full at 0 amp hours, and 50% at -750 amp hours (I guess the batteries hold 1500 amp hours total). Lately it seems full is somewhere between -100 and -200, probably closer to -200, and 50% is around -560. Thanks for the quick reply earlier. It's really hard to find people who know about this the stuff. The electrician who set it up isn't totally sure about it all. -
Oh, and maybe the Trace thing isn't working right. I ran the generator for a while and then restarted it, as I said earlier. It had switched to float during the first run, and the trimetric which had said maybe 75 amps (not amp hours) had gone to about 20 amps when it switch to float from bulk. When I started the generator after stopping it for a bit, it went back to bulk, and started putting in 75 amps, which slowly climbed into the 90s. Not sure what that means. -
Re: Reset amp hours question(I guess the batteries hold 1500 amp hours total).
That would be a huge battery bank! typically as we desire higher capacity we increase the voltage, by running the batteries in series. If you have a 1500 amp hour battery in the 48 volt range this would represent 4 strings of standard L-16 batteries (8 batteries to a string for 32 batteries)
You might check your specs...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
I think I figured it out. There's something called a charge controller (I think that's what it's called), and it can actually tell you when the batteries are full. A friend told me about it a few hours ago, and when we looked at it it said they were charged (probably had been for a while). So I zeroed the trimetric thing. Not sure what the trimetric thing is, but the trace thing is the inverter, and apparently it doesn't really know exactly what the batteries are doing.
As far as the amp hours, I think the system is 12 volts. The trimetric come up with readings from about 12.5 to 14.45 on the volts setting depending on when you check it. Anyways, it's really cool how you helped answer my questions. I really appreciate it. -
the charge controller's job is to allow a battery or batteries to reach full charge without overcharging. an inverter converts the dc voltage to a higher voltage ac.
it concerns me that you have these items and haven't a clue as to what they do. where did you get the stuff from? who put it together? -
There are several different criteria that will reset the Trimetric to full. Look at page 5 of manual attached. It depends on voltage, current, and time.
Run generator and keep the battery between 14.2v and 14.4 vdc for an hour and it should reset the Trimetric to full. -
If these are Flooded Lead Acid batteries then the best way to see how they are is to use a Hydrometer.
Charge the batteries, when in Absorb mode watch the current come down. When they are "full" then do an EQ. After the EQ you can reset the AH on the Trimetric.
Using the charge controler isnt the best way to see if your batteries are full. -
Re: Reset amp hours questionit concerns me that you have these items and haven't a clue as to what they do.
He doesn't have those items. As he said in the OP, it's his mom's gear. -
Re: Reset amp hours questionHe doesn't have those items. As he said in the OP, it's his mom's gear.
i don't see how that makes a difference for if his mom knows then why ask us? -
Re: Reset amp hours questioni don't see how that makes a difference for if his mom knows then why ask us?
Coot razzed the guy for not knowing about his gear. I said, "it's not his gear".
In other words, don't raz the guy for not knowing about his gear - when it's not his gear in the first place and he already said it wasn't his. -
razzing is not what i'm doing because it's "not his gear". follow?
- 628 Discussion Forums/Café
