OutBack temp sensor
offgrid
Registered Users Posts: 20 ✭
Hello everyone,
Have any of you experienced the temp sensor losing it's "stick" on the battery post ? What can I do to fix ?
Thanks !
Thanks !
Re: OutBack temp sensor
Chewing gum, duct tape, pine sap, duct tape...4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Hello off..
You should be able to scrape off the old double-sided tape and replace it with new (a single-dege razor blade should be perfect for the task).
You could prob glue the sensor down with RTV/Silicone, which is good adhesive, but also easily removable should you wish to move it later.
VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Thanks Vic,
I thought about the silicon, but I like the idea of scraping/replacing tape. -
Re: OutBack temp sensorChewing gum, duct tape, pine sap, duct tape...
You forgot staples.
"Windows Hardware Auto-Detect
New hardware found: Wood Screw." -
I tried temp sensors on bat post and found that the heating from the charge source to the cables + post gave a very false reading compared to bat internal temp,
At the start of charge, The post will heat a lot quicker than the internals and back your V off prematurely,
New bit of (thin) double sided tape and on the outside of your warmest cell about half way up is my suggestion,
Have a good one
Tim -
Re: OutBack temp sensorYou forgot staples.
Couldn't think of anything else witty, I was off my game that day.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Re: OutBack temp sensorblackswan555 wrote: »I tried temp sensors on bat post and found that the heating from the charge source to the cables + post gave a very false reading compared to bat internal temp,
Maybe your cables are not large enough, or have some crud at the interface ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: OutBack temp sensorMaybe your cables are not large enough, or have some crud at the interface ?
New Rolls batteries, Rolls supplied interconnects, nuts/bolts/washers, All connections cleaned and greased on assembly, C10 charge current, Sensor placed on + internal terminal (Not on actual connection)
Tim -
Re: OutBack temp sensorblackswan555 wrote: »New Rolls batteries, Rolls supplied interconnects, nuts/bolts/washers, All connections cleaned and greased on assembly, C10 charge current, Sensor placed on + internal terminal (Not on actual connection)
Tim
I have never seen this on my system becasue I am solar and it heats up slower.
My generator folks might see this but I doubt it. Have you tried another sensor?"we go where power lines don't" Sierra Nevada mountain area
Re: OutBack temp sensorHave you tried another sensor?
Have a good one
Tim -
I did not know outback made a sensor for the terminal? Xantrex makes both and they are very different BTW."we go where power lines don't" Sierra Nevada mountain area
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
