If the Auto Industry can...Can we do the same?
BilljustBill
Solar Expert Posts: 219 ✭✭✭
Here is an article about Ford's twist of getting longer life out of their coming hybrid battery packs by liquid cooling. I've read that the Toyota Prius has a 90 volt air cooled battery pack that has an eight year unprorated warranty....Anytime it goes out during the eight years, it is replaced at no charge...
http://www.autoblog.com/2010/09/04/2012-ford-focus-ev-to-use-liquid-cooled-lithium-polymer-battery/
If the auto industry is using cooling and heating to extend the life and performance of their batteries, what ways are you using with your battery banks?
Bill
Re: If the Auto Industry can...Can we do the same?
Electric autos are using very high discharge and charge rates that heats up batteries. -
Re: If the Auto Industry can...Can we do the same?Electric autos are using very high discharge and charge rates that heats up batteries.
Roughly, the "typical" lead acid battery specs are round 77F --- Hotter batteries will have "more capacity" but shorter life... Colder batteries will have less capacity and longer life (typically use: for every 10C, the life of the battery will be 1/2--and for every 10C cooler the battery is, it will last 2x longer, 20C colder, 2*2=4x longer, etc.).
For long term life--I would be very worried if a battery was much over 100F for any length of time...
The use of batteries for solar typically doesn't have the huge charging cycles that heat up batteries.
The simple solution is a berm shelter for the batteries, using the naturally mitigated temperatures of the earth, figure a thickness near the frost level for northern areas, perhaps 24 inches thickness for southern climates, should reduce super high tempuratures, 4' would likely keep you near 80 degree max (a guess)Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
- 628 Discussion Forums/Café
