MS tristar MPPT software
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
Well, I had no trouble at all loading new firmware, but didn't get past step 1 with programming new setpoints, or retrieving log files.
Had no trouble id'ing the device, but after getting connected and a delay while it downloaded the logs to somewhere, is as far as I got. And off grid, with no web or phone is tough.
So, I've got the fridge hooked up, the water pump is working, and the water miser caps are on order.
And, any ideas on how to "dial in" the power factor for a water pump ? The XW6048 claims 950W when it's running, and it's only a half HP pump @ 240V (Grundfos 10S05-9, Franklin 3 wire) ? Add a "run" cap ? Magic Power factor corrector ?
Mike
Mike
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: MS tristar MPPT software
Mike,
Your need the MSView software, once connected, run the TriStar Wizard if you want step-by-step on the set-points and options.
Or, download the current settings, then select edit , make the changes and then save them back to the controller. By the way, you not down loading log files, you retrieving the current settings.
On the XW, sounds about right, most AC pumps are horrible efficiency wise, my 3/4HP pool pump pulls 1300 watts vs 754 watts = 1 HP
SG -
Re: MS tristar MPPT softwareSolar Guppy wrote: »Your need the MSView software, once connected, run the TriStar Wizard if you want step-by-step on the set-points and options.
Was running the MS sw, I'll try your suggested sequence.
Also, only was able to work via the serial port. Got nothing using the MS dongle, other than a connection ack. Used an Edgeport 8 USB/serial adapter.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike
When I inherit a client with a pump like that it is the first thing to go! I assume this is not the well pump but a pressure pump for the house. You need to go DC and lose the surges and out of "our" league power consumption. Nice to have one like that for a wildfire though..."we go where power lines don't" Sierra Nevada mountain area
Re: MS tristar MPPT softwareFranklin 3 wire
Re: MS tristar MPPT softwareDave Sparks wrote: »Mike
When I inherit a client with a pump like that it is the first thing to go! I assume this is not the well pump but a pressure pump for the house. You need to go DC and lose the surges and out "our" league power consumption. Nice to have one like that for a wildfire though...
Nope, a grundfos well pump, 160' lift @ about 10 gpm. Pumps from a pond (sunny hours only, via a manual switch) up to 3ea 3,000gal tanks. Just running it an hour a day, gives me 600 gallons or so. Tank elevation gives me all the pressure I need.
Earlier estimates led me to believe I had about 120' of tank elevation, which would have better for both gallons/watt and pressure, I don't need 62psi, but that's where the terrain allowed for tank pads. Have to have 2,000 gal on hand, under pressure, at a hydrant, for CalFire.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
OK, a well pump! So what is the problem with an hour a day? I am with SG, that is pretty normal for that type of pump. Are you just wishing it was less?"we go where power lines don't" Sierra Nevada mountain area
Re: MS tristar MPPT softwareDave Sparks wrote: »OK, a well pump! So what is the problem with an hour a day? I am with SG, that is pretty normal for that type of pump. Are you just wishing it was less?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If it is a "plain induction motor"--then yes, a you can use a motor run cap to get the power factor closer to 0.9 or so (I think you don't want to try for 1.0).
You really need to measure the power factor (volts, amps, phase/PF or VA) to know. It is possible that the inverter is really reporting VA instead of Watts (P=V*I*PF does not equal V*I=VA in AC circuits).
And even then, bad power factor may limit the maximum load you can put on the inverter--but may not affect your true DC power that it consumes that much (just higher I^2 * R losses because of the higher current the motor consumes with "bad power factor"). It would be interesting to see how much the inverter's input power is reduced if you do correct the PF).
Given that a Grundfos pump (as I understand it--I am no expert) has its own electronics/controller (because it can take AC or DC from battery/solar panels)--I would think it would not have a "bad" power factor). And that a Motor Run Cap would not be appropriate for this installation (and in fact, may cause you other problems with inverter stability).
So, I would get some more information from Grundfos before I put any line cap on there.
Mike, I can buy into doing this to make the inverter run cooler or have more energy available, but you said make the batteries last longer??? It is running off the sun right? You are not doing this at night? Totally agree with Bill except you can't really hurt much other than the pump which has easy access. It is not down 300 feet or deeper like the ones I have to worry about up here in the Sierra.
I am with you on trying to get it lower and your priorities sound right as you have the refrigerator running;) Is this going to be permanent soon I hope!
Oh yea, do you have a shunt or clamp-on DC that you can measure the DC?"we go where power lines don't" Sierra Nevada mountain area
Re: MS tristar MPPT softwareYEP. 0.5hp should be about 400W
http://www.franklin-electric.com/business/WaterSystems/Service/AIM/page-13.aspx
I think your pump motor would be the 6th one down in the table and shows about 670 watts running and about 960 average starting. The power factors are also given. -
Re: MS tristar MPPT softwareHere is a link
Standard induction motor, not the fancy DC/AC electronic controller motors. I'll save the $, and buy 2 more panels
It's the 240V 3 wire 214505. I looked it up yesterday, and discovered I'd have to change the controller out, the electronic relay can't deal with a run cap. Spec for run cap was 15uf @ 400V. So I'm not sure what the XW shows, I thought it displayed the current watts (KW) , but there's more menus than I had time to go through. I'm only pumping around solar noon, after batteries are bulked up. And it's hard wired 240V so I can't put it on my kill-a-watt meter.
(motor spec claims 23A start/locked, the 960 is max load at full service factor, not locked rotor)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike,
Did the firmware work? Also what is your impression of the display panel for this unit? What if there were 2 CC's on the display. I may be needing a few for a project? SG R U around?"we go where power lines don't" Sierra Nevada mountain area
The TriStars have network features, ( not talking about the http stuff ) you need the MS Meterbus hub. You can mix mppt and pwm units as well on the network
A single LCD can view all parameters of any meterbus networked charger regardless where the LCD front/remote panel is located. There are system level screens that totalize all the connected units or you can drill down into any of the individual connected chargers
Currently, the maximum number of support LCD front/remote panels is 5 when networked, doubt that would effect anyone though.
The online documents show all the available screens of the TSM-2 ( product name for the LCD ) -
Re: MS tristar MPPT softwareDave Sparks wrote: »Mike,
I got the firmware (A & B sides) installed and working (passed checksum) and that's just fine. And some more pointers to try the custom setpoints on my next trip. Never got the log pulled off, didn't have time to puzzle out how the management software worked. I'll have to do that another time. Not having a manual that can be printed is a real pain, pop-up help screens only go so far....
Display panel is essential, it ships with the very crudest panel.
Anyone know if Morningstar has a users forum ?
MikePowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks Mike & SG !
I was concerned about when networked how hard or easy it would be for one of my tech challenged customers to access the data. The one I have is just being used for yard lighting for now and I am trying to decide between this model and the xwcc for this project. I really find the scroll mode of the xw to be flawless so I am concerned I am going regret it with 2 CC's.
SG is the remote panel TSM-2 comparable to the SCP-2 in ability to read the display?
better, worse, or the same?"we go where power lines don't" Sierra Nevada mountain area
The SCP is a significant advancement over the TSM-2. It has a large graphical display, the data transmission is in the megabits per second so data access is instant.
The TSM-2 provides adequate data and will provide system level totals, but the data rate is ~9600bps so updating is slower than the Xantrex remote
The scrolling feature in the XW was my idea, could easily be put into the TSM-2 if customers think its a useful feature. For the average Joe, the TSM-2 with simple screen, layout and menus would probably be a better choice.
I really like the SCP unit ( have one myself ) but even for an engineer is a bit of a stuggle to figure out out menu does what IMHO -
Thanks so much SG ! nice perspective as usual... Really helped me to avoid going backwards from the SCP from one of my techless customers. As an engineer it is easy to knock them sometimes but I always remember that many of them have skills that many of the Tech world do not. For instance, several of them can feed themselves off the land up here.
By all means tell Morningstar that the scroll feature would be enough for me to switch over in many cases! I would add to it (because engineers are always changing things) by making the scroll alpha/numerics as big as possible for the older guy's! Stay cool down there!"we go where power lines don't" Sierra Nevada mountain area
Well, I'm actually getting log files in .XML format, but I've got no idea what's in them, excel just gives me a empty spreadsheet with column headings - no way to figure how to view offline, the graphs I was able to view while connected.
MS View wants to load a .csv file, but only saves .xml Arghh!Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: MS tristar MPPT softwareWell, I'm actually getting log files in .XML format, but I've got no idea what's in them, excel just gives me a empty spreadsheet with column headings - no way to figure how to view offline, the graphs I was able to view while connected.
Try opening the xml in an advanced text editor like Notepad++ or Ultraedit and see if there is anything there other than column headings. -
I'd upload it if the file type was permitted, any .xml experts or Morningstar gurus want a whack at it, send me an email, and I'll send a copy to you.
sample excerpt:
<?xml version="1.0" encoding="ISO-8859-1" standalone="yes" ?>
<morningstar>
<loggeddata version="1" model="0" type="8" set="8">
<record retrievalTime="2010-08-23T04:47:33.000+00:00" retrievalHourmeter="3337" hourmeter="1302">
<variable id="100" value="no flags" />
<variable id="102" value="59.23" />
<variable id="103" value="49.75" />
<variable id="104" value="109.34" />
<variable id="106" value="332" />
<variable id="107" value="1890" />
<variable id="110" value="0" />
<variable id="111" value="152" />
<variable id="112" value="0" />
</record>
<record retrievalTime="2010-08-23T04:47:33.000+00:00" retrievalHourmeter="3337" hourmeter="1313">
<variable id="102" value="50.62" />
<variable id="103" value="49.58" />
<variable id="104" value="99.16" />
<variable id="106" value="10" />
<variable id="107" value="50" />
<variable id="111" value="0" />
</record>
<record retrievalTime="2010-08-23T04:47:33.000+00:00" retrievalHourmeter="3337" hourmeter="1319">
<variable id="102" value="59.14" />
<variable id="103" value="49.53" />
<variable id="104" value="108.00" />
<variable id="106" value="409" />
<variable id="107" value="2320" />
<variable id="111" value="131" />
</record>
<record retrievalTime="2010-08-23T04:47:33.000+00:00" retrievalHourmeter="3337" hourmeter="1323" hourmeterDiscontinuityBefore="1">
<variable id="100" value="power on reset, alarm occurred" />
<variable id="102" value="55.90" />
<variable id="103" value="50.26" />
<variable id="104" value="104.18" />
<variable id="106" value="4" />
<variable id="107" value="20" />
<variable id="114" value="Controller was Reset" />
</record>
////// skip to end \\\\\\
<record retrievalTime="2010-08-23T04:47:33.000+00:00" retrievalHourmeter="3337" hourmeter="3337">
<variable id="102" value="58.81" />
<variable id="103" value="48.24" />
<variable id="104" value="107.25" />
<variable id="106" value="1600" />
<variable id="107" value="8820" />
<variable id="111" value="434" />
</record>
<record retrievalTime="2010-08-23T13:49:48.000+00:00" retrievalHourmeter="3345" hourmeter="3345" hourmeterDiscontinuityBefore="1">
<variable id="102" value="50.93" />
<variable id="103" value="50.10" />
<variable id="104" value="54.38" />
<variable id="106" value="0" />
<variable id="107" value="0" />
</record>
</loggeddata>
</morningstar>Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike, I would suggest you send an email to MS support, I'm sure they can give you the documentation to decode what values link to which operational parameters to work offline
SG -
Re: MS tristar MPPT softwareSolar Guppy wrote: »Mike, I would suggest you send an email to MS support, I'm sure they can give you the documentation to decode what values link to which operational parameters to work offline
SG
I actually got an offline email from them, and there is a new version of software out, that I will try.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I've installed the new (8-2010) morningstar View software, merged my 2 .xml files, and was able to load it into the software, AND export it as a .CSV, which Excel was able to understand. And it's readable. Now I'll start making up some charts from the data. I'm feeling better, and may run and get the logs off the Sunsaver and Suresine in the little shed too!Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 628 Discussion Forums/Café
