Solar assisted golf-cart set up.
sunflexsolar
Registered Users Posts: 5 ✭
I just wanted to get some ideas on what other member's opinions would be for the best solar set-up for a golf cart?
Re: Solar assisted golf-cart set up.
What is it you are looking for?- Panel on a cart?
- Off-Grid Charging?
- Grid Charging?
- Operate at night/charge during day?
- How much power (Amp*Hours at XX Volts, or Watt*Hours per day)
- Where (near what major city?)
- Seasons (4 seasons, summer/sunny months only)
- etc.
A panel or 2 on a cart, is just showing off, it has no chance of recharging the battery bank before the batteries sulfate, and will extend your range in a day, for about 40 '.
Build a carport, cover it with PV panels, and Grid Tie it to your electrical service. If you are off grid, you charge the cart with panels daytime, and use it as your household batterybank at night.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 628 Discussion Forums/Café
