BYPASS DIODES
midijeepmidijeep Posts: 88Registered Users ✭✭
I have Solarworld sunmodule SW 345 XL panels.  I want to have a few backup diodes for the panels.  I took the cover off and there is a solid white silicon block inserted in the casing to protect the everything in the panels junction box, so I can't see the numbers on the diodes.  Can I go off the panel voltage and current specs to pick the proper diodes for the panels?
