Inverter Brand Suggestion
WandaFletcher
Registered Users Posts: 5 ✭
Hi, I am looking to buy MicroSolar/aims inverter as they are priced good. I asked few of my friends but no one have used this brand. Anyone with negative feedback, if any?
I need to make a choice between MicroSolar or AIMS inverter if they both are ok to go with
Both are on the low rungs of the ladder of quality, do expect noise on radios as even the pure sine waveform is not so pure, you do get what you pay for. For general purpose they may be acceptable, just don't expect perfection, that way you won't be disappointed.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
