Extended warranty available for Inverter?
Some have so many exclusions, that they really don't cover anything when it's all said and done.
Will have about 520 watts solar, 450ah battery bank, Morningstar Tri-Star MPPT 45, etc...
Thanks in advance
Greg
Some credit cards offer to extend the manufacturer's warranty, or even to cover accidents, theft, etc.
I think some retailers (including marine retailers) sell Magnum and offer extended warranties for a price.
--vtMaps
I'll check with some of the online dealers and see if they do. I thought about SquareTrade, but I have not followed that up at all. You get used to having an inverter and you don't want it to fail. Especially out of warranty!
wb7duo said:I'll check with some of the online dealers and see if they do. I thought about SquareTrade, but I have not followed that up at all. You get used to having an inverter and you don't want it to fail. Especially out of warranty!
A good reason for having a separate small inverter for critical loads, which may also be useful if the tare on your larger inverter is uncomfortably high.
Or, of course, using two stacked inverters instead of one large one.
The well pump (which you do not have in an RV!) or other really major loads that are critical will just have to run off the generator only.
SMA SB 3000, old BP panels. -
Outback inverter i think comes with 5 years standard.2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
I have been considering a small PSW for electronic and computers, but by the time I buy the small one, and a Large MSW, I may as well get the bigger one. But the tare as you mentioned is high. The new Samlex EVO series seems to have a feature to shut down if nothing is using it.
petertearai; Didn't know they came with 5 years. I'll look closer at them.
Many inverters have a 'standby' mode, during which they use very little energy, ...but it take leaving just one thing plugged in...
I think other inverters have a 5 year warranty as well. Of course a warranty doesn't mean something will not fail, and I doubt you will want to wait on a warranty replacement, though I have heard of quick replacements...
...something nice about having a backup or a spare. Many people who have started small and grown into a larger system have a spare that they have outgrown, also knowing the value of a spare I have picked up a couple 'deals' on inverters when I've seen them... So the 10 year old inverter running my household is likely the least dependable of the 4 inverters I currently own. It had a fan fail in it and I replaced it a couple years back. I have an identical one from my cabin and a Military version that I picked up very cheaply. and a smaller Exeltech, that I had always wondered about and purchased when I could for a 3rd of new...
I just pieced together a magnum system. Most components were acquired at a deep discount.
Particularly in my case the advanced remote control had old firmware. I recently bought the new magnum mppt charger. The display on the arc was not displaying mppt info mppt was still working just in standalone mode.
Contacted magnum by email on a Friday. Was hoping to get a response within a few days. I got a response back with in a out 2 hours from a fellow named Darren. My email had some technical questions. And was answered by someone that knew something. Seems to really know his stuff. They offered to reprogram my ARC at no additional cost.
I have no idea. How their extended warrenties are. But I was very impressed by quality of service.
I like my magnum as it has both 120/240 coming out. Without the need for stacking o external transformer.
Also like the fact I can feed inverter 120 or 240 and it handles everything. I think something thatmaybe very useful in an Rv.
My statements about my inverter does not apply to all magnum inverters.
Final note. Posted from a small smart phone. Sorry for typos. -
Wish I could find a 'Deep Discount' on some of these inverters. They are spendy. But I sure like the quality and reputation of the Magnum line. Like many inverters though, Picking one that will handle the battery voltage on a cold day from the solar charger TCP. Or when equalizing. 15.5vdc may not be enough. Though some in the product line go higher.
Thanks for all your comments!
wb7duo said:We have a 40' Newmar 5th wheel that I am getting ready to put solar on and will be adding a 3000 watt inverter. Probably Samlex EVO or Magnum. But, these are quite an investment. $1500 and up, plus all the install pieces. Do any of you have any experience with buying an extended warranty that is really worth having? Either enhances the MFG warranty, or covers when it stops.
Thanks in advance
Greg
What are you running that you want a 3000w inverter? If that is a 12v system, that is 250 amps! You will need extra large wiring and terminators. It is really a fire waiting to happen. Samlex is a very good brand and they do make smaller inverters that also cost much less.If you really need that much power, you are much safer (and much less expensive to wire, etc) with a 24v system or even 48v. Also, depending on your batteries, they might not be able to handle a 250 amp load, which would take the battery down below 50% in less than one hour.
I may also use a smaller (300 watt) PSW inverter wired just for my electronics. TV, dvd, computers, phone chargers. The big one would only switched on as needed.
I have considered 24volt, but my entire Rig is 12volt. I don't like the idea of having to deal with both voltages.
But initially, still wondering about an extended warranty...
Thanks for the input.
That's a good idea!! Keep 20% of your solar install put away for unexpected, after warranty breaks and repairs.
- 299 In the Weeds--Member's Choice
