Solar panel protection
Where I live we get hail and lightning. By hail I don't mean nickel and pea sized stuff the east coast sees once a decade. Nickel and pea size is a non event here unless its falls in amounts that get measured in inches. Golf ball size hail has fallen on my address twice in 4 years and a line of soft ball size hail some how missed me by maybe 100 yards, it ruined houses in the nice part of town.
I hear lightning and hail are bad for solar panels as they are for most things.
What if I were to just put a grounded grid of something like chicken wire in a frame under slight tension suspended maybe a foot above the panels.
If it gets hit by lighning and vaporizes a 1 foot hole in the wire or base ball size hail beats the chicken wire beyond recognition I would be out like $19.
It wouldn't even have to totally stop the hail, just slow it down. Totally stopping the hail or catching it would be a real bad idea, we had one storm dump 3 inches of marble and nickel sized hail in one go.
I am going to guess even the cheap panels with 3mm tempered glass could easily shrug off marble size hail?
Even if the glass does not shatter the panels getting pummeled with golf ball size hail cant be doing the solar cells contained within any favors.
A couple of tall metal (grounded) flagpoles will work as lightning rods (look up Rolling Sphere Model)
But hail is going to be tough. Maybe a steeper angle, to deflect it a bit more, but then if there is wind, it may be at the "wrong" angle, Call your insurance company and order Full Coverage ?
we get golf balls here too. as a rule panels are guaranteed for 25mm hail at 25m/s. they are suprisingly strong.
1 1/2" hail at least, panels did fine, car looks like a golf ball, still does...
Hail did come in at a glancing angle, but took out many car windows, that were not so lucky.
- 228 Forum & Website
- 815 Wind Power Generation
- 618 Discussion Forums/Café
- 311 In the Weeds--Member's Choice
