Xantrex XW Series Hybrid Inverter
drraptor
Solar Expert Posts: 218 ✭✭
Do these inverters require separate Charge controllers ? http://www.solar-electric.com/nexaxwseinan.html Or the built-in charge controller are enough ?
Re: Xantrex XW Series Hybrid InverterDo these inverters require separate Charge controllers ? http://www.solar-electric.com/nexaxwseinan.html Or the built-in charge controller are enough ?
Do all model of Xantrex can work in "Grid zero" or such modes ? -
Re: Xantrex XW Series Hybrid InverterDo all model of Xantrex can work in "Grid zero" or such modes ?
Grid Zero is a Outback Inverter term, they use it as a Grid / Generator support term for load support in reverse. The Inverter carries the load and the Grid will help support a portion of the load that the Inverter can't.
Attachment not found.
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
