Panel mounts with wind deflectors?
FS2020
Registered Users Posts: 1
I'm getting ready to install solar pv panels on my roof. My roof is almost flat. I want to attach the mounts to my roof, because my roof is built on 2 ft engineered trusses and is very strong. I am trying to find a commercial mounting system that has wind deflectors. I designed a mounting system using unistrut (schematic below), but I now want to find a company that makes mounts with similar wind deflectors. Companies that sell mounting systems will usually provide wind load certifications that will help with getting code approval. I live in a suburb that is infamous for difficult code approvals.
Anyone know of companies that make mounting systems with wind deflectors?
Thanks!
Frank
Attachment not found.
Thanks!
Frank
Re: Panel mounts with wind deflectors?
I'm curious as to why you want to add a wind deflector to a standard rack. Are you concerned that the more common installation won't be strong enough in your situation?
- 226 Forum & Website
- 134 Solar Forum News and Announcements
- 198 Solar Information links & sources, event announcements
- 815 Wind Power Generation
- 617 Discussion Forums/Café
- 310 In the Weeds--Member's Choice
