Mounting 3 axis accelerometers on a blade??
SH Yang
Registered Users Posts: 9 ✭
Good Day,
Is there anyone using 3 axis accelerometers on a wind blade or turbine to measure vibration??
I have not used 3 axis accelerometers, however, I should use this type..
(Ive used only 2 axis ones..)
I was trying to google how to mount, but seems not clear enough.
My questions are like below.
1 - Could I use 3 axis accelemeters without board??
Attachment not found.
2 - how to collect the data from the accelerometer??
( I think the board should be connected like the attached.)
Attachment not found.Attachment not found.
Actually, I am going to attach several accelerometers on a blade.
So far, mounting several 3 axis on the blade seems impossible..
Do I need to just use 2 axis accelerometers??
- 227 Forum & Website
- 135 Solar Forum News and Announcements
- 198 Solar Information links & sources, event announcements
- 815 Wind Power Generation
- 617 Discussion Forums/Café
- 310 In the Weeds--Member's Choice
