wiring up my solar in the next week or two.. any tips?
spanel
Solar Expert Posts: 36 ✭✭
Can you guys throw some tips my way before i start wiring all this stuff?
Stuff that I dont want to overlook?
Like for example.. put a blanket over the panels before connecting wires to them... stuff like that..
Thanks!
Chris
Thanks!
Chris
Re: wiring up my solar in the next week or two.. any tips?
Have MC -3 or -4 jumper cables and disconnect tool on hand. Or know how to get them quickly. Never cut or splice a panel's intergal cord, it voids the warranty.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Connect batteries together first.
Connect charge controller to batteries second.
Connect panels to charge controller third.
Connect inverter to batteries fourth.
Check each circuit for function as you go so there are no surprises when you turn the inverter on.
Double check wiring before energizing it. Don't rush any part of the job.
Do not forget the fuses/breakers! -
Include a battery monitor in your system from the start.2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
Have a big bag of lots of UV resistant tie wraps and the little square plastic blocks with adhesive on them used to attach tie wraps to flat surfaces. It doesnt take much longer to route things properly and cut wires to length (except leads with connectors) and makes for a lot better looking job.
Use stainless fasteners with nylock nuts. They arent that pricey if you buy them by the box from a marine distributor like Hamilton Marine and they arent going to rust or stain.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
