Solar Panel Frame Seaside Corrosion Requirements
Anyone can advise whether the anodized aluminum frame of the solar panel can withstand the corrosive safty seaside environment?
  • mike95490mike95490 Solar Expert Posts: 7,409 ✭✭✭✭
    Re: Solar Panel Frame Seaside Corrosion Requirements
    GOOD, true, anodize will last. If there are pinholes in the conversion coat, the salt will begin eating from the pinholes. I suspect much of the commercial anodizing is loaded with pinholes. I'm 3 miles from the coast, and I hope my frames last.
    Good Luck
  • nigtomdawnigtomdaw Solar Expert Posts: 705
    An annual coat or two of quality automotive car wax/polish should seal up them pinholes nicely ?
  • System2System2 Posts: 6,290 admin
    Thanks guys, but then sound like the anodized frame won't last. Well, nigtomdaw and mike, your views do help, appreciate that. Anybody know even a little more, share please..
  • Solar GuppySolar Guppy Solar Expert Posts: 1,959 ✭✭✭
    I have never, ever heard of issues with solar panels and being in a salt enviroment. As far as the panels, your worrying for no reason, now the mounting structure should be built in aluminum as well, if this is done build it and for get about it
  • VolcanoSolarVolcanoSolar Solar Expert Posts: 56
    Unprotected aluminum will corrode.
    Anodized aluminum holds up fine; painted aluminum holds up fine; but any chips or scratches need to be attended to, perhaps in the way of annual maintenance.
    It also depends on the degree of "seaside" -- do high winds carry the ocean spray right onto things on a regular basis? That's a lot more severe than, say, the occasional salt in the air.
