Just checking
I have 2x100, 1x85, and 2x60 pv panels. How many 6v Golf Cart batteries hooked up for 12v operation can i recharge if discharged to 50%. How would you hook up the panels for maximum power to recharge these batteries
Re: Just checking
Let's see ...
2 @ 100W = 200W
1 @ 85W = 85W
2 @ 60W = 120W
Grand total: 405 Watts of mis-matched panels which probably have different Vmp & Imp but I wouldn't worry too much about that on a small, 12V system.
Potential charge current from those panels: 405 * 80% efficiency (probably less due to mismatching) = 324 Watts @ 14.2 Volts charging = 22.8 Amps which is about 10% of 225 Amps - the 'standard' rating for those golf cart batteries.
So the answer is: probably you can get away with two 6 Volt 225 Amp/hr batteries in series.
Please note I didn't include losses from wires and charge controller, environment, etc. But it ought to make the minimum 5% current (11.25 Amps) anyway.
Harvest-wise, you're looking at roughly 300 Watts * 4 hours of good sun (if you've got it) for approximately 1.2 kW/hrs per day. Not bad for a small system.
But in AC terms it would probably be more like 800 Watt hours per day. -
Re: Just checking
We really need to know more--- What is the Vmp*Imp for each type of panel you have (and how many of each).
- What kind of charge controller you have (or are thinking of getting)
- Ideally, we really need to look at the loads you want to drive.
"Station Identification"
"City:","Little_Rock"
"State:","Arkansas"
"Lat (deg N):", 34.73
"Long (deg W):", 92.23
"Elev (m): ", 81
"PV System Specifications"
"DC Rating:"," 1.0 kW"
"DC to AC Derate Factor:"," 0.520"
"AC Rating:"," 0.5 kW"
"Array Type: Fixed Tilt"
"Array Tilt:"," 34.8"
"Array Azimuth:","180.0"
"Energy Specifications"
"Cost of Electricity:"," 7.4 cents/kWh"
"Results"
1, 3.78, 59, 4.37
2, 4.38, 61, 4.51
3, 5.19, 78, 5.77
4, 5.67, 79, 5.85
5, 5.89, 83, 6.14
6, 5.81, 77, 5.70
7, 5.93, 80, 5.92
8, 6.08, 83, 6.14
9, 5.41, 73, 5.40
10, 5.16, 75, 5.55
11, 3.69, 53, 3.92
12, 3.56, 55, 4.07
"Year", 5.05, 856, 63.34
So for a 1,000 watt array, we would expect an average of 53-83 kWhrs per month or 1.8 kWH to 2.8 kWH per day (depending month/seasons) per 1,000 watts of solar panels.- 2x100, 1x85, and 2x60 pv panels = 405 Watts of solar panels
- 1,800 WH per day * 405w/1,000w = 729 WH per day
- 2,800 WH per day * 405w/1,000w = 1,134 WH per day
- 729 WH / 100 watt load = 2.29 hours per day
- 1,134 WH / 100 watt load = 11.34 hours per day
- 405 Watts * 1/17.6 volts * 1/0.05 rate of charge = 460 Amp*Hours maximum
- 405 Watts * 1/17.6 volts * 1/0.13 rate of charge = 177 Amp*Hours minimum
Re: Just checking
To some extent, the "real" answer is more dependent on your loads. How long does it take you to get to 50% DOD? How fast (or slow) are you willing to be in recharging? How often do you have such loading? Every day is one answer, once a week is another,, and 6 weekends a year is still another.
That said, other charging options might (should?) change things as well. do you have grid power 24/7 to charge, do you have a gennie,, is it properly sized with an efficient charging system?
As Marc, suggests, I would be surprised if you see more that ~20 amps out of the PV inot a 12 volt battery bank.
Just FYI, we live off grid with ~400 watts of PV into 450 ah of trojan T-105 batteries. We see just about 20 amps on an normal day, nearer 30 with winter cold and reflection off the snow. We draw the T-105s down ~60 ah/day on average,, just over 10%. If we don't have sun for three days, I will run the gennie for a few hours, but a full sun day will bring them back from 70% to nearly 100% by the end of the day. (depending on the time of year) January,,no June, maybe but March with long days and lots of snow,, easily.
