two separate panel/controller to one common battery bank
I have two separate solar panel/controller systems of which the 50watt panel I use to charge my fishing motor battery separate from the 125watt panel/30 amp Trace controller I use for the rv. When not in use can I clamp the 50 amp panel/6a controller to the battery bank which I use for the 125 panel system. The battery bank is 225 ah deep cycle batterys. Thanks
Re: two separate panel/controller to one common battery bank
Not sure what the question is here - and I assume that you mean 50 watt and 125 watt, not 50 amp panels.
If you just want to know if you can do, then yes. -
Yes , I meant watt, and I think you understand the two separate systems to one common battery bank. Basically I would clamp the smaller panel through its own controller to the battery bank. I have 15 amp fuse from battery to each controller. Thank you guys. This site is awesome!!!! -
as was said you can do that as long as it is only the battery that is kept in common to the 2 separate systems meaning don't share the pvs to the 2 controllers and then back to the shared battery. -
I would run each pv/controller separate to the common battery bank as I understand you responce. Thank you.
- 231 Forum & Website
