shunts
tnhunter
Registered Users Posts: 13 ✭
I am installing a ground fault into my off grid system. My shunt is not tapped to add a negative buss bar to it. Can I use the bolt that attaches the negative from the battery to also secure a buss bar to attach all my negatives to or do I have to buy a new shunt with the buss bar?
Re: shunts
Two things...- You need to have a thread or two above the nut/lock washer when all of the lugs are tied to the shunt "buss point".
- Make sure there is no undo loads/stresses from the heavy/inflexible cables that would try to pull the shunt apart.
Also, in the end, it may be easier with a separate bus bar to return different sized cables (14, 8, 0, etc.) cables back the battery bus point vs trying to put ring lugs for 1/4" post (or whatever size the shunt posts are) for the wide variety of wire sizes. (many bus bars have captive screws and do not require any cable termination/crimping).
Re: shunts
Kamala, the "sawdust" part confuses me ..... who was the suppler and was it expensive??? -
Re: shunts
:roll:
Sawdust was removed last November when the camper was stored.
But... I (the vendor) will be providing ample quantities in a few more weeks.
The bigger picture. -
Re: shunts
OT: I see one very big problem. The batteries are not tied down. -
Re: shunts... The batteries are not tied down.
That will be taken care of. Trailer is parked permanently for the time being.
- 234 Forum & Website
