ultracapacitors / supercapacitors
audredger
Solar Expert Posts: 272 ✭✭
Could someone convert Farads to amps? I'm trying to figure out how much juice one of these things hold? http://www.maxwell.com/ultracapacitors/products/modules/bmod0165-48-6v.asp
The PDF on the large one (BMOD0165) says Nominal capacitance 165 F.
"They" used these as a UPS for the Palmdale sewer plant. Could they be used as a battery bank? Or, am I just smoking stuff that I ain't sharing?
Re: ultracapacitors / supercapacitorsCould someone convert Farads to amps? I'm trying to figure out how much juice one of these things hold? http://www.maxwell.com/ultracapacitors/products/modules/bmod0165-48-6v.asp
Not sure there's a direct conversion. A while back there was a news release about hybrid battery/supercapacitor. There could be some future in this.
But until NAWS starts selling them, don't hold your breath waiting!
Data sheet (PDF). Lets assume the "big one" at 165 Farads, 48.6 volts charged, 10.5 volts discharged. 150 Amps continuous rating:- Watts Seconds Stored = 1/2 * C * V^2 = 1/2 * 165 F * (48.6 volts) ^2 = 195,000 Watt Seconds
- Watt*Hours = WS / 3,600 seconds per hour
- 195,000 WS / 3,600 sph = 54.2 WH full
- WS Left Behind = 1/2 * C * V^2 = 1/2 * 165 F * (10.5 volts) ^2 = 9,000 WS (not much)
- 9,000 WS = 9,000 WS / 3,600 sph = 2.5 WH "empty" of usable energy
- P=I*V= 150 amps * 48.6 volts = 7,290 Watts Peak (beginning of discharge)
- P=I*V= 150 amps * 10.5 volts = 1,575 Watts Minimum (end of discharge)
- (54.2 WH - 2.5 WH) * 1/1,500 Watts * 0.80 eff = 0.034 hours = 2 minutes
- (54.2 WH - 2.5 WH) / 12 volt bank = 4.3 AH 12 volt Bank
I noticed they spec. a "cycle" as Vmax to 1/2 Vmax--so the useful energy stored will be a bit less.
To show this on a other calcutalion.
A 1-farad capacitor can store one coulomb (coo-lomb) of charge at 1 volt. A coulomb is 6.25e18 (6.25 * 10^18, or 6.25 billion billion) electrons. One amp represents a rate of electron flow of 1 coulomb of electrons per second, so a 1-farad capacitor can hold 1 amp-second of electrons at 1 volt.
So 156F * 48.6V = 7581.6 Asecond that is 2.1Ah.
This shows that the capacitor is perfect for sort time buffer. but not replacing batterys.
Even for a car charging from braking is aproblem , think how often are you braking a day , and you will see that you will waist the supercap. 1.000.000 c/d life time whitin a year.:grr
It is a nice product but to early to replace the old battery even if you forget the extra money.;)
greetings from Greece -
This capacitor is rated in charge/discharge cycle lifetime? That is strange...usually caps are rated in years only due to aging of the dielectric (unless it is air or some other durable material). A capacitor in an AC circuit might see 1,000,000 cycles in a single day!
Yet another way to look at the storage is I = C dV/dt In other words, a 1 Farad capacitor discharging at a 1 A current will drop 1 volt per second. If there was a way to pull a constant 1 A current from a 1F cap charged to 10V, in 10 seconds it would be totally drained. -
@Skyko,
This are not normal caps thats why the life cycle.
The local metro company in Athens greece is using this to buffer on there trains ( the new ones from korea) and is replacing whitin one year the supercaps.
Greetings from Greece8) -
Thank you all.... B.B. you once again amaze me, Marc the supercap + battery was designed for the Ev market where they need a surge buffer for braking & acceleration.
I guess my batteries are safe for now!? I can remember the TV repair man using a long grounding wand to discharge the "cans' in the back. They would hold a charge for years. That and the article about the Palmdale ups generating megawatts for seconds, well... stinking thinking.
Once again, I thank you all! Amps, volts & hours I understand but, farads.... I guess "they" didn't think a turbine mechanic need to know about capacitance. (13,820 rpm x 5,000 lbs of fuel / hour = 5,000 hp = ? farads) does not compute -
Amps are a flow of electrons, Farads are a quantity of electrons.
Basic equation is: CV = IT
Capacitance (in Farads) X Voltage (in Volts) = Current (in Amps) X Time (in Seconds)
1 farad of electrons at a charge of 1 volt will flow 1 amp for 1 second
In a dynamic situation, the math gets much worse.
- 234 Forum & Website
