Battery backfeeding into charger?
Steve961
Solar Expert Posts: 93 ✭✭✭✭
I just finished connecting most of my electronics today, except for the solar panels, and thought I would test everything out. When I hooked up the battery, I noticed that the light on my Iota IQ4 Smart Controller was blinking. Is power supposed to backfeed into the charger? I'm a bit concerned that even a small power loss occurring 24/7 could impact my total available power - this is for a small off grid cabin.
Do I need to have some sort of inline switch to prevent this? I'm really hoping I don't, as I already installed an inline 40A fuse for it. It would also be a pain to have to manually turn the switch on and off when I use my generator.
Thanks.
Steve
Thanks.
Steve
Re: Battery backfeeding into charger?
I have the same thing with a DLS-75 at my cabin (Michigan's U.P.). I haven't measured how much juice it uses, but I haven't noticed a problem. I do have it on a breaker, and I flip the switch when I leave.
If you find out what the power consumption is, I'd be interested in knowing. -
I contacted Iota Engineering today and asked this question of them. They said that the DLS-30 battery charger with the IQ4 Smart Charge Controller would only consume 1-2 milliamps of power. If I unplugged the IQ4 they said it would consume less than 1 milliamp. So, it would seem that this is a non-issue.
Steve -
can you confirm what they say to be true with a current measurement? -
Niel:
Unfortunately I do not have an Ammeter, so I will just have to take them at their word for now.
