Combining Solar Panels??
54d18
Solar Expert Posts: 81 ✭✭✭
I currently have 2-75w Siemens Panels,
could I connect 2-80w Sharp panels into
my system without trouble?
Re: Combining Solar Panels??I currently have 2-75w Siemens Panels,
If the VMP's are within 10% of each other their should be no problem.
Is this a parallel or series connection? -
My 75w panels are presently connected parallel
at 12v, I would be reconfiguring my solar array
to 24v when I add more panels.
I am patiently awaiting a Rogue controller, on its
way as we speak, my old controller was a shunt,
that's why I am at 12v. -
In this instance, what you're wanting to do will work out perfectly. Instead of seriesing the new panels with the old panels, parallel one old panel with one new panel, then series the two identical "12V" pairs to each other. You'll end up with a perfectly balanced 24V system.DoD= depth of discharge= amount removed from that battery SoC= state of charge= amount remaining in that batterySo, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoCA/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use) -
Actually, you also need to look matching the Imp within 10% too.
If the Vmp of the panels is "close enough"--just put the matched pairs in series and add the strings in parallel.
It really depends on the specifications of the panels you have on-hand...
- 230 Forum & Website
