Wrap Panel cables around framework?
pbartko
Solar Expert Posts: 37 ✭✭
I have a question for everyone. Is there a standard out there for what to do with the extra length of cable between neighboring solar panels rack mounted on a roof? Do you typically wrap the cables around the frame or just attach them in several places with wire ties or loop clamps?
Thanks in advance!
Pete B
Thanks in advance!
Pete B
Re: Wrap Panel cables around framework?
i would think the latter as you would loop it upon itself and just tie it with plastic cable straps to a rail underneath up and out of the way. i hope we aren't talking about allot of excess in wire as that introduces more resistive losses than is necessary. -
Zip ties are the most common and you can get them UV rated.
There are also metal clips made for this.
Some rail systems have channels for it. -
Thanks for the info,
I am planning on using stainless steel loop straps with rubber inserts that are screwed into the Unirac Frames. I'm trying to get a feel for how many I need to purchase per panel since one loop strap can only hold a single cable?
Thanks,
Pete B
- 234 Forum & Website
