Calculating MY PV Power & Load
tcvb
tcvb Solar Expert Posts: 44
It's been a while since i had to use my Head with Ohms Law but here is a general idea of what i have in mind + my budget.
I am tying to piece together my system starting off with a few Kyocera 135 Watt panels,looking at a couple of Trojans T105'S,gOT A ProStar 15 solar charge controller.
Have a Sunforce 1000 Watt PSW inverter.
What i am looking at doing is possibly power maybe 600 to 800 watts of lighting load at night for 7 to 9 hours.
Like i said it's been a while with Ohms law anybody want to chime in and give me a quick refresher on the equations to figure my bank and panel needs that i may need.
Thank's Alot i am in the learning process and i think this Forum is awesome not to mention the people at the store also.
    Re: Calculating MY PV Power & Load
    Working backwards:
    • 800 watts * 9 hours = 5,600 Watt*Hours per day.
    Using PV Watts for Norfolk Virginia, assume 1kW of solar panels (round number), 0.52 derating (120 VAC output, flooded cell battery bank):
    "Station Identification"
    "City:","Norfolk"
    "State:","Virginia"
    "Lat (deg N):", 36.90
    "Long (deg W):", 76.20
    "Elev (m): ", 9
    "PV System Specifications"
    "DC Rating:"," 1.0 kW"
    "DC to AC Derate Factor:"," 0.520"
    "AC Rating:"," 0.5 kW"
    "Array Type: Fixed Tilt"
    "Array Tilt:"," 36.9"
    "Array Azimuth:","180.0"
    "Energy Specifications"
    "Cost of Electricity:"," 8.0 cents/kWh"
    "Results"
    1, 3.84, 61, 4.88
    2, 4.53, 65, 5.20
    3, 4.69, 72, 5.76
    4, 5.47, 78, 6.24
    5, 5.40, 78, 6.24
    6, 5.69, 77, 6.16
    7, 5.44, 75, 6.00
    8, 5.61, 79, 6.32
    9, 5.02, 70, 5.60
    10, 4.95, 74, 5.92
    11, 4.04, 59, 4.72
    12, 3.37, 52, 4.16
    "Year", 4.84, 839, 67.12
    Assume 9 months of the year solar only. And 3 months of the year, with genset backup. Give us 65 kWhrs per month per 1kW of solar panels:
    • 65 kWH per month / 30 days = 2.17 kWhrs per day per 1kW of panels
    • 5,600 WH / 2,170 kWH per 1kW of panels = 2,585 watts of solar panels
    I can go further--but this gets things started (or I misunderstood your requirements).
  • tcvb
    Working backwards:
    Bill,
    Thank's for the response so i will need about 28 100 watt panels?
    TVCB,
    It really depends on what your needs are... I guessed at your location, and guessed at your power requirements, and guessed that you would have a back up genset to run 3 months of the year (plus the occasional streak of bad weather during the other 9 months).
    What I gave as a panel estimate is a goodly amount of power (and costs)--is this what you need/want (we are probably talking about a $25,000-$40,000+ system (SWAG) here by the time you add batteries, charge controllers, inverters, backup genset, etc.).
    Normally, I would be asking you about conservation (choosing the most efficient lighting and lowest acceptable levels). And asking if motion detector controlled lighting would be acceptable.
    Is this intended for a long term installation (5+ years) or short term. Will there be fuel available / backup genset? Does it need to be self monitoring (i.e, start backup genset, shutdown loads if battery bank charge is low and genset does not start, etc.)...
    I am more than happy to help you size the system--but there is only so much I can do before I would tell you to talk with a local professional to hammer out the system details (we try to educate enough that a person can followup the details with a local supplier). I do not sell or design solar RE equipment.
