Differences between Outback inverters (GTFX vs FX)
RandomJoe
Solar Expert Posts: 472 ✭✭✭
So I'm killing some time tonight browsing the NAWS store and reading up on the Outback inverters. I noticed the FX and GTFX inverters are the same price for a given voltage/wattage. If I were to buy one of these, are there any major differences between the models that would influence that decision? (Aside from GT versus non-GT, of course!)
Thus far the only differences I've come across are that the GT series can't be stacked in as many different ways, and they have a tighter AC input frequency tolerance. Is there anything else?
I also noted the NAWS page for the GTs says "not recommended for use with AC generators". Why is that? Frequency tolerance? (In which case, would using an inverter generator with stable output frequency work okay?) The possibility of damage if Sell is enabled and you backfeed the generator? Or some other problem? I haven't found any mention of that in the manuals yet, but not gone through them cover-to-cover either. Just thinking what-ifs, if the grid is down and I need to recharge the batteries...
I don't currently plan to go grid-tie, but it's certainly not outside the realm of possibility. If I were to buy one of these, for the same price it might be nice to have the functionality available if it doesn't negatively affect another feature I may find more useful...
Re: Differences between Outback inverters (GTFX vs FX)
Not a GT user but from my readings over on the outback forums http://www.outbackpower.com/forum/?page_id=forum The GT will work with inverter type generators but not with 99.9% of "normal" gens,
Again from other readings so please confirm, I believe if you do want to change to GT after, You can send unit to OB for conversion & certification,
Have a good one
Tim -
Yeah, I forgot about the Outback forums. Thanks for the reminder, I'll go rummage around over there too!
