Poor Man's rooftop Azimuth Tracker...
Re: Poor Man's rooftop Azimuth Tracker...
IF you are going to mount them like blind slats they would need good spacing so not to cast a shadow on the one next to it -
No kidding, the maximum practical azimuth (roll) would be limited to about +/- 45 degrees, which at 15 degree/hr earth's rotation would significantly improve collection for the middle 6 (9a-3pm local sun time) keeping perpendicular illumination. Spacing of 70% panel width would be sufficient to avoid shadows, outside those hours, you would need to reduce roll proportionately.
If I go up to 60 degree tilt to pick up an additional hour, that would put the spacing at 1.5X panel width.
- 230 Forum & Website
