Looking for: Thermometer
TnAndy
Solar Expert Posts: 249 ✭✭
I'm looking for an analog/dial type thermometer with a probe 4-6" long or so, and pipe threads on the backside of the dial so I can screw it in a tank of water and do some experimentation with several projects I have in mind.....one is passive solar water heating for a small greenhouse.....one a wood fired water heater ( I have a COOL stainless steel tank that was made for gas fired WH, )...another is active solar water heating of that same greenhouse if the passive doesn't do the trick.
NOT interested in anything electronic or battery operated....just a simple dial type face, range of 50-200 degrees F, or thereabouts. Pipe thread size not too critical, can bush it up or down as needed.....1/2" or 3/4" would be ideal.
I KNOW I've seen them, I KNOW they are made.... but a search of Google and WW Grainger neither return what I want......so you know of one, please post.
Thanks !
andy
Thanks !
andy
Re: Looking for: Thermometer
Got this with some google searching (don't know anything about companies/products):
http://www.weissinstruments.com/bimetal.html
http://www.indiamart.com/japsininstrumentation/temperature-instruments.html
Graingers appears to have some--on closeout sale, so you may get a deal--or get nothing?
http://www.grainger.com/Grainger/wwg/productIndex.shtml?L2=Temperature&operator=prodIndexRefinementSearch&originalValue=dial+termometer&L1=Gauges%2C
http://www.houseneeds.com/shop/HeatingProducts/HydronicHeating/gauges/temperaturegaugebuypage.asp
http://www.grainger.com/Grainger/items/2A615
Opps BB beat me -
Re: Looking for: ThermometerSolar Guppy wrote: »
Yeah, but for $10.50, you hit the bullseye ! Plus that site has a boatload of other cool hydronic stuff.....
Thanks fellows...... -
Well gee--nice way kick a guy who tries to help...
