Another noob question
Re: Another noob question
maybe you might find some of these locally, but you can always send for one if not.
http://search.store.yahoo.net/cgi-bin/nsearch?catalog=wind-sun&query=hydrometer&searchsubmit=Go&vwcatalog=wind-sun&.autodone=http://store.solar-electric.com/ -
They are all flimsy and apt to break.
Except the plastic ones which are just plain no good.
Look for one with a fine scale on it. There's a company called Freas which makes a ridiculously fine scaled version: 1.250 to 1.275 in 0.002 increments. This is 'overkill' in my opinion.
There's also a type with built-in temp compensation, sometimes called a "thermohydrometer".
Here's a place with some examples (not to be interpreted as a recommendation):
http://www.remybattery.com/Departments/Battery-Testers/Hydrometer-Battery-Testers.aspx
Should give you some idea what to look for (although that site is short on specs). You ought to be able to find one locally and for reasonable money.
Oh; don't ask for a "hygrometer" or you'll get a device for measuring ambient humidity.
That bottom one for $10.34 looks exactly like the one I got at Checker Auto for $4.99.
I'm gonna put some shrink tubing around the ends of the glass tube. It only takes a light bump there and they split up the side.
