115V/60hz Solar Grid Tie inverter
Dear members,
We are searching for a 500W-700W, 115V/60Hz solar inverter for the Suriname market.
Can anyone help us to find a fine, reliable inverter to be send to The Netherlands?
Regards Tom-
Regards Tom-
Re: 115V/60hz Solar Grid Tie inverter
A couple of choices:Enphase Micro-inverter Grid-Tie Systems
SMA Sunnyboy Grid Tie Inverters
700 to 7000 Watts
Are you sure you want Grid Tied? Not off-grid inverters that run on batteries?
From our host's (NAWS) website:
http://store.solar-electric.com/suboy70700wa.html
Most grid-tie inverters tend to be larger, except the Enphase 190W units. They are almost always 230-240V as well. -
an interesting note i should mention is that i remember seeing a small 240w batteryless gt inverter being offered by exeltech.
http://www.exeltech.com/downloads/pvacbrochure.pdf -
Suriname is actually 127 VAC 60 Hz, but I guess that is close enough to 115 - 120. Or is it?
http://treehouse.ofb.net/go/en/voltageNorthern NM, 624 watts PV, The Kid CC, GC-2 batteries @ 24 VDC, Outback VFX3524M -
Electrical Operating Range: 108-132VAC, 59.3 to 60.5 Hz
i think it's covered. -
Re: 115V/60hz Solar Grid Tie inverterMountain Don wrote: »Suriname is actually 127 VAC 60 Hz, but I guess that is close enough to 115 - 120. Or is it?
It's virtually impossible to hold system voltage close enough that 120 versus 127 would matter. Most electric systems in the States are 120/240 +/- 5%, with +/- 10% being the absolute upper bound.
What I'd check for is the permissible system range.
