Series and Parallel question
Can I wire panels of different wattages together? I have an 85 watt panel already and would like to add one additional panel. The cost difference between an 85 and 135 watt panel isn't much. Obviously I want to get the most power for the buck. As long as my charge controller is able to handle the resulting watts and amps I shouldn't have a problem right? As you can probably tell...........when it come to electricity I need stick figure and crayon drawings! LOL
PS These are on a 12 volt system!
Re: Series and Parallel question
As long as the Vmp of the panels is close (within 10% or so) then paralleling different wattage panels isn't too big of a problem.
Although Solar Guppy is the true expert on this sort of thing, not I! -
Yep--a god estimate is to parallel panels that have Vmp within 10% of each other.
And to connect panels that are within 10% of Imp.
The other thing to add--if you get more than two panels in parallel, you need series a protection fuse for each series string. This protects a shorted panel from overheating by being fed from the other "good panels" (the approximate fuse rating should be larger than Isc and less than ~2xIsc -- if the panel spec. sheet does not list the value of the series protection fuse).
Thanks for the answers! Of course now I have to print this out and do lots of checking when I get back to the house in 2 weeks. -
actually it wouldn't be a bad idea to fuse both pvs or at least one of them in case it gets wired baclwards. this is cheap insurance and it doesn't just protect the wiring all of the time as wiring backwards can damage one or both pvs.
- 234 Forum & Website
