a software question about xw config tool
t00ls
Solar Expert Posts: 283 ✭✭✭✭
I currently have the xw config tool program running. I'm using the apox can to usb an dan lenox's pd lite program
what I want to do is put the logging info on my website so it continuously updates every 2 - 3 minutes on the site.
I'm using Linux ubuntu server 8.4 and cant get either program to run on ubuntu,I tried using wine,but it didnt work.
my question is ,does anyone know of a program that will run on ubuntu that will work with the apox can to usb for an xw system and how would I go about getting the info to update in a webpage automatically
any help appreciated
12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw )
Re: a software question about xw config toolI currently have the xw config tool program running. I'm using the apox can to usb an dan lenox's pd lite program
What's the interface to the Xantrex box? I'm looking to add Xantrex support to my software and perhaps we can help each other out a bit here. -
Re: a software question about xw config toolWhat's the interface to the Xantrex box? I'm looking to add Xantrex support to my software and perhaps we can help each other out a bit here.
There are two major lines, the GT inverters and the XW products. The GT inverters are RS232 and a simple ASCII command/response protocol, I wrote what xantrex gives away ( GT-View ) and offer for free SG-View which is a updated version for free on my site
The XW line uses Xanbus, which is Modbus over CAN, the lowest cost PC interface is over 100 bucks. Its a very robust but complex architecture that only some of the details are public knowledge. For example, 3rd party vendors are prohibited from even making setting changes or it will invalidate the warranty ... while this might seem draconian, its to protect user from software that could brick or blowup the hardware.
Its a major undertaking and there is virtually no market as Xantrex already has XW-Config that does everything including logging, firmware updates ect that they give away for free. -
Re: a software question about xw config toolSolar Guppy wrote: »There are two major lines, the GT inverters and the XW products. The GT inverters are RS232 and a simple ASCII command/response protocol, I wrote what xantrex gives away ( GT-View ) and offer for free SG-View which is a updated version for free on my site
Source code? Or at least, ASCII protocol description?The XW line uses Xanbus, which is Modbus over CAN, the lowest cost PC interface is over 100 bucks. Its a very robust but complex architecture that only some of the details are public knowledge. For example, 3rd party vendors are prohibited from even making setting changes or it will invalidate the warranty ... while this might seem draconian, its to protect user from software that could brick or blowup the hardware.
If Xantrex can't come up with an interface that protects itself from bad 3rd party software, perhaps that's yet another reason to be thankful I have Outback gear?Its a major undertaking and there is virtually no market as Xantrex already has XW-Config that does everything including logging, firmware updates ect that they give away for free.
Right, but there's still a market for monitoring in ways that I suspect the don't do. Like, what one sees if they here or here.
Those people at Fat Spaniel aren't doing it for the heck of it, and if I can climb into the backside of their market, I'll be more than happy to do so.
