connecting a solar array
System Posts: 2,511 admin
This is very basic but I am doing some research so here goes:
I am looking a solar panels that use MC4 connectors and it appears to me that you can only connect them in series, +ve to -ve.
But I want to run a 12v system and connect a few panels in parellel. How do I do it or am I misunderstanding something?
  • RandomJoe
    RandomJoe Solar Expert Posts: 472 ✭✭✭
    Re: connecting a solar array
    You use something like this:
    http://store.solar-electric.com/mumc4colam.html
  • System2
    System2 Posts: 6,290 admin
    Aha! Thanks for the help.
  • lorelec
    lorelec Solar Expert Posts: 200 ✭✭
    If you're handy with a soldering gun, you could always cut the connnectors off, solder the wires together, and heatshrink the connection with some glue-lined waterproof tubing (or something similar). Not as elegant as the adapter method, but cheaper and probably more reliable.
    Marc
    One reason to not cut the connector(s) off of the panels is that, for many vendors, it will invalidate the warranty.
    Generally, if you only have a few connections to make up (and don't want to purchase the correct crimping tools)--just get a male/female cable from here, and cut them in half... Use those for your transition connections.
  • lorelec
    Sounds like a ploy to sell couplers ;)
    Marc
    lorelec wrote: »
    Marc
    Or a ploy to sell salvaged/returned material as new. ;);)
