Kohler 17RES Generator Auto Start Contacts
AlanRT
Solar Expert Posts: 57 ✭✭✭✭
Can anyone tell me if the generator auto start connection on the Kohler 17RES generators are a straight simple 2 wire connection to an Outback Inverter or charge controller, or do you need to use an isolation relay triggered from the Outback gear?
Re: Kohler 17RES Generator Auto Start Contacts
With most generators using the Outback you need an isolation relay http://store.solar-electric.com/regest12vosi.html -
The Outback AUX output is 12v / 700ma max (on FX , 200ma on MX) you will need to use a relay, A Bosch type automotive relay is fine,
Have a good one
Tim
ps if you do a search on the outback site for "AUX OUTPUT" it has been discussed many times -
Alan,
The generator's spec sheet (pg. 3) indicates "remote two-wire start/stop capability". It's not clear to me if it'll need an intermediate relay.
See: http://www.kohlerpower.com/onlinecatalog/pdf/g4120.pdf
The 12 V auto relays are cheap... probably OK to get one (or two) and then use it if you need it once you've had a chance to spend an exciting Saturday night going through all of the manuals...
HTH,
Jim / crewzer
