Under 20 watts, 12 v Solar Panel
I am looking who sale 10-15 watts, 12 vol panels that are not expensive. I found one place that wants $ 75 for 10watts, 12 v. Can anybody help with this,.....
Re: Under 20 watts, 12 v Solar Panel
do a google search. i know that sounds harsh or brash, but most here deal with larger pvs and it is a given that the smaller ones will cost more per watt. ebay may have some and i don't need to tell you that you could windup getting burned in such a bargain search.
maybe we should ask you why you are looking for such panels? -
Several problems... Typically, smaller panels cost more $$$/watt than the larger panels.
Another issue is what kind/brand of panel are you purchasing... The small panels can be found for cheaper prices--but they are usually amorphous silicon panels and cheaply made... You will probably have a drop of 20% of your power output over the first few months, and they may only last a few years.
Otherwise, local ads and Craig's List are going to be your cheapest source--hopefully, you can test the panel(s) in full sun with a DVM to see that they at least work.
Re: Under 20 watts, 12 v Solar Paneldo a google search. i know that sounds harsh or brash, but most here deal with larger pvs and it is a given that the smaller ones will cost more per watt. ebay may have some and i don't need to tell you that you could windup getting burned in such a bargain search.
thanks for you time anwering my question. -
Re: Under 20 watts, 12 v Solar PanelSeveral problems... Typically, smaller panels cost more $$$/watt than the larger panels.
no, thanks you for listening to the answer. -
Those who already have professionally installed multi-thousand Watt systems on your home, wonderful for you. But some of us don't have the capital to lay out, and are doing installs ourselves. Smaller panels are great for those still experimenting, and not wanting a large investment up front. Take it easy on us new guys!
Solar panels are also great for maintaining batteries on boats, RVs, etc. I have a lowly 5W panel on my boat doing just this task. Yes, only $39, and yes an Amorphous panel. The battery is happy, and so am I.
http://2manytoyz.com/solarcharger.html
Northern Tool has their 15 Watt panels on sale once again for $79.99. I have 3 of these on my roof for the past year. Obviously not as well built as the 130W Kyocera panels that I've added next to it, but they are still holding up well in the FL environment. http://www.2manytoyz.com/solarphase2.html
These come with a 5 year warranty. http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200263174_200263174
Smaller panels do have their uses. Not the cost efficient way to cover an entire roof, but ideal for newbies still experimenting, and for smaller projects. -
For battery maintainers, if you live near an ocean port that imports cars, see if you can talk to someone there and get some of these...
http://cgi.ebay.com/ebaymotors/VW-solar-panel-voltage-at-max-power-18-8-v_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1171Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem280323660552QQitemZ280323660552QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1522wt_1135
Thousands of imported cars have these stuck to the inside of the windshield as they sit in the big parking lot after they are unloaded from the ship...
-N. -
For just trickle charging a battery I have gone to:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200305091_200305091
Put one of these on my backhoe that always seemed to lose it's charge b/t uses.
And bought 2 of these for my horse trailer, I may put more on it and add batteries.
Reason... they are sturdy, are in a hard formed plastic frame, with mounting holes.
$5.33/watt
Yes they are amorphous.
Rancher -
try to refrain a bit on the referenced company for you sound like a commercial. i'm giving the benefit of the doubt on your post, but i can't say anybody won't act on your post especially in lieu of any complaints.
- 228 Forum & Website
- 618 Discussion Forums/Café
