how make the connection to the ground??
Hi
I have a little solar system but i don´t maked the protection to the ground yet someone can to tell me how to do that??
I have
one solar panel 53w
one controller 12amp
one battery 134 ah
one charge 250w
one inverter 750w
Thanks!!
I have
one solar panel 53w
one battery 134 ah
one charge 250w
one inverter 750w
Thanks!!
Re: conection to the ground??
that depends on the inverter here as some modsine inverters do not take kindly to being grounded. that is assuming it is modsine as you did not state any makes or models of equipment or how you plan on using this setup and where. you might be able to ground the pv frame, but again we don't know what it is you have. -
Re: how make the connection to the ground??
If the solar panel has a metal frame. I would just ground that for lighting protection.
- 654 Solar Water Pumping
