series or parallel
I have (2) 110w solar panels (16.40 volts 6.7amps) charging (3) Group 31 Lifeline AGM batteries and controlled by a Solar Boost 2000 with temperature monitoring. Should my panels be wired in series or parallel? If I wire them in series how will shade affect effieciency?
Re: series or parallel
the sb2000 is a 12v controller only so parallel them. series pvs would exceed the maximum input voltage. see the specs in this pdf or read your manual.
http://www.blueskyenergyinc.com/pdf/SB2000Edatasheet.pdf -
Thanks for the reply Niel. Would I be better off with another controller and wiring the panels in series? These panels are charging (3) Group 31 Lifeline AGM batteries. -
The SB-2000 float voltage is also higher than that recommended by Lifeline. -
Bmats,
Watts are watts are watts. Series, parallel, series/parallel,,, the battery doesn't care in the end. What matters is the length of wire run from the panels to the batteries, the longer the run, the more advantageous it is to run higher voltages. That said, with only two panels, ~220 watts of pv it probably wouldn't be cost effective at this point to change out the cc. If memory serves the sb 2000 is a mppt controller that does a pretty good job of converting as much sun into power into the batteries (net) as most anything else. The advantage of parallel is that shading of one panel ill not affect the output of the other like it would if you were to wire them in series. If you went with a bigger mppt controller and ran the panels at 24vdc I think the size of the panels would cause the controller to operate in a quite inefficient range.
I second the notion of reading the battery and cc manuals.
Tony -
that would depend on some things. seriesed pvs are nearly always utilized in very large arrays of pvs to reduce the size of the wires used or in the case of long distances between the pvs and controller. if you wish to check if your wiring is too small or long for your system that would benefit from placing the pvs in series or larger wire you can check here, http://forum.solar-electric.com/showthread.php?t=29
another factor may be if you plan to expand in the future and by how much. otherwise there isn't any difference to series/parallel for your 2 pvs. remember that the 25a rating is output and not input and should not exceed 20a input. i think there was a discussion not too long ago on this controller and its ratings that may be good to search the forum for. -
Niel, thanks again. Moe, Icarus thanks for your input. -
one more point brought up by moe is that the sb2000 does not have a float charge to it and will continue to charge based on the absorb charge setpoint being it is a 2 stage charger. this is a case of diminishing current as it is charged at that voltage setpoint, but you may want to check with concorde (they make lifeline batteries) if that will hurt the batteries or not. this is the case for a few other pwm controllers out there like the sunsaver series (not the sunsaver mppt though) as they are also 2 stage chargers. the 14.0v factory absorb setting is too low for lifeline batteries too as a range between 14.2v and 14.4v should be used and it is recommended for a battery temperature sensor to be used no matter the controller. (assumes controller can accomodate one) -
Re: series or parallelone more point brought up by moe is that the sb2000 does not have a float charge to it and will continue to charge based on the absorb charge setpoint being it is a 2 stage charger. this is a case of diminishing current as it is charged at that voltage setpoint, but you may want to check with concorde (they make lifeline batteries) if that will hurt the batteries or not. this is the case for a few other pwm controllers out there like the sunsaver series (not the sunsaver mppt though) as they are also 2 stage chargers. the 14.0v factory absorb setting is too low for lifeline batteries too as a range between 14.2v and 14.4v should be used and it is recommended for a battery temperature sensor to be used no matter the controller. (assumes controller can accomodate one)
Thanks you for your help,
Ben
- 228 Forum & Website
- 618 Discussion Forums/Café
