New grid-tied system with pics
GunnyD
Registered Users Posts: 5 ✭
Re: New grid-tied system with pics
shadetree engineering with actuator -
Looks good. Can see why they call it shadetree, that thing is huge!! -
Re: New grid-tied system with picsLooks good. Can see why they call it shadetree, that thing is huge!!
143 sf !!
By "shadetree engineering" I meant like "shadetree lawyer" or shadetree mechanic", self inflicted pain, I designed and built it myself. I plan on adding a vertical axis actuator next year so it will twist and bow to the sun. -
I'd be concerned about the spacing on the supports for the 2x2 rails which are the panel attachments
You only have thee attachment rails over the span of 5 panels, 2x2 don't have the strength or rigidity to keep the panels from twisting in winds. Its VERY important for solar panels that the support structure has no movement or high winds could cause the glass to crack. I'd double up the 3 rails to 6 and shouldn't be to bad to add in on the completed array
Also, how much concrete is in the base?, as a guess you would need about 5-6 yards for code. Very professional look, much better than anything I've ever built! -
Re: New grid-tied system with picsSolar Guppy wrote: »Also, how much concrete is in the base?, as a guess you would need about 5-6 yards for code. Very professional look, much better than anything I've ever built!
Thank you very much!! The 8inch sch40 pole is 200 inches with 80 inches in a 36 inch dia hole dug with a jackhammer through hardpan, it took 1.25 yards of concrete and has alot of rebar to reinforce.
