New DR series from Trace !
nigtomdaw
Solar Expert Posts: 705 ✭✭
See Xantrex have launched a new revamped DR series under the Trace Corporate band, has a more sophisticated Info Display and power factor corrected charging all built in,to list a couple of inprovements is this the new no brainer Cabin Inverter;)
Re: New DR series from Trace !
Here is the press release link http://www.xantrex.com/web/did/1827/readnews.asp -
it's like a model t car with all of the bells and whistles. they did not say they changed the modsine waveform at all so no matter what way you shake it, it's still the same output.
cabin? i don't think a cabin usually has need of a 120vac charger. -
Agreed,Niel but I sucessfully used a DR yes the learning curve on what would and wouldnt fry was irksome but they have there place and there price market, Just using one as a PFC charger has its merits if the price isnt much a hike over the old DR units. They are still MOD SINE WAVE
- 616 Discussion Forums/Café
