MX 60 Set Up vs Operating Manual
Mangas
Solar Expert Posts: 547 ✭✭✭✭
Maybe a question for Jim. I was organizing the manuals for my system and ran accross the set up manual for my Outback MX 60s'. It's pretty brief, 10 pages or so.
Is there a more in depth version which goes into more detail about the MX 60's operation and features? If so, where is it available?
I really need to get a better understanding of its operation. The forum has helped a great deal.
Thanks everyone.
Thanks everyone.
Re: MX 60 Set Up vs Operating Manual
Mangas,
The current MX60 production firmware is revision 5.11. Here's a link to the the latest complete user manual for revs 5.10 and 5.11: http://www.outbackpower.com/pdfs_manuals/MX60_REV_%20C.pdf
HTH,
Jim / crewzer -
Hi Jim,
As always, you're there with the life preserver.
I'm getting more confident in understanding basic charger technology and have some homework to do. Behind the screen, I know they're complicated little instruments.
Hope this finds you well and thanks.Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers -
Jim,
Just accessed the link.
Perfect.Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers
- 226 Forum & Website
- 617 Discussion Forums/Café
