Differential Thermostat
                    Brianellul
                    Solar Expert Posts: 95 ✭✭
                    Can anyone recommend a good differential thermostat similiar to the 'Kera tech DSD-2'? I've read in an article of Home Power about someone who used it in a Water Solar system but I can't find it on the net... their website is down!
Regards
Brian
      Regards
Brian
            Re: Differential Thermostat
 From an earlier thread here... One guy used this controller... And other link on the same thread, another guy decided to build and market his own DC powered differential controller.
 Don't know anything about the vendors or the controllers other than what I have read on their websites...
 Of course, from the Home Power article (PDF file), they listed Kera Tech's address:
 Kera Technology, Andy Lukas, 1320 Midway Blvd., Unit
 21, Mississauga, ON L5T 2K4, Canada • 905-566-0823
 Fax: 905-566-9036Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
 I recently purchased a Steca 301 differential controller for a solar hot water system. I have been very satisfied with this unit and the many programmable options it provides. This unit is made in Germany and was reasonably priced.
 This is proving to be a nightmare!!!! I found the Steca 301 differential controller specs really attractive BUT it seems that I'll be having a problem to have it shipped to Europe since all of the suppliers I found on the net don't even answer back my emails. Well I guess I have to keep on looking
 Regards
 Brian
 Steca is a German company--Try www.stecasolar.com and see if they can help you directly...
 By the way, I fixed my link to the GL-30 controller that was used in this project...
 I think a GL-30 would work just fine on 230/50hz. I have used the GL-30 and its a great contoller and very reasonably priced
 http://www.solar-components.com/gl30.pdf
 The differnce in 240vac/60hz and 230vac/50hz for this devices would not make any operational difference
 This thread was about differential thermostats and turning on/off a pump to move hot water to a "cool" water storage tank for solar hot water.
 Your issue sounds like your thermostat is set for Celsius/Centigrade scale instead of Fahrenheit.- 20C = 68F
 Today's electronic thermostats are pretty reliable. And you can get many that are very programmable (programmable temperatures during the day, and even ones that will randomly turn on the fan to filter your air).
 Define your needs then pick one that will fill them.
 I'd say you're right, Bill, except that 20 C is 68 F:
 degrees Celsius * 1.8 + 32 = degrees Fahrenheit
 (degrees Fahrenheit - 32) / 1.8 = degrees Celsius
 Try these formuli with 0C (32F), 100C (212F), and -40 (same in both systems).
 I grew up dealing with both, and still can't get away from having to do Metric/Imperial (and SAE) conversions!
 Marc,
 I goofed. Was in a hurry and added 36 instead of 32.
 Bill Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
            Hi, I purchased the following differential thermostat based on the recommendations I read in other forums and I'm also very pleased with the quality:Hope it helps..
            You can try differential thermostats from brands like Goldline, Resol, or SunEarth. Models such as the Goldline GL-30 or Resol DeltaSol are reliable alternatives to the Kera Tech DSD-2 for solar water heating systems.
            You may want to consider the SunDanzer or Rish thermostats; they’re both solid options for solar water heating systems. Additionally, consider Auber Instruments, which offers some suitable differential thermostats that may be suitable for your needs.
- 232 Forum & Website
