Which One is Better For Solar Battery ? LFP or NMC?
jennyzhang
jennyzhang Registered Users Posts: 31 ✭✭
There are a few key things to consider when you’re shopping for a solar battery, including the battery’s performance, its lifespan, its safety, the cost, and its overall value.
Let’s take a look at how NMC and LFP batteries stack up against one another.
Performance
Winner: Tie
In general, the overall performance of NMC and LFP batteries are pretty much the same. You can find both types in a variety of sizes, from as little as 3 kWh to over 20 kWh. Most homeowners only need around 10 kWh of storage, which you are sure to find from both types.
With that said, there are some slight differences between the two. LFPs are slightly more efficient and can operate a little better when the state of charge is low compared to NMCs, but NMCs can better withstand colder temperatures. However, you probably won’t have to worry about this if your battery is installed inside, or if your area doesn’t experience significant temperature extremes.
NMC batteries also have a higher energy density, meaning that their physical size will be smaller than LFP batteries of the same capacity. This isn’t usually a concern for homeowners, but if you do have limited space then you may need to consider an NMC battery.
Lifespan
Winner: LFP
As you use a battery, it loses some of its ability to hold a charge. Think of your cell phone - you probably need to charge it more frequently now than you did when you first got it. The same thing happens to solar batteries.
Degradation happens more slowly with LFP batteries, so they’re able to store and release more electricity than NMC batteries over time. Keep in mind that the quality of the battery will also play a role in how long it will last, so you might want to read through the product warranty before you make a decision.
A cheap, poorly made LFP battery might not outlast a high-quality NMC battery. But, you’re probably not going to come across many shoddy batteries, so long as you choose a reputable installer.
Safety
Winner: LFP
One of the biggest benefits of choosing an LFP battery is its safety. The combination of lithium iron phosphate is more stable than nickel manganese cobalt at higher temperatures.
Plus, LFP batteries can better handle larger draws of power. Because of this, LFP batteries are less likely to experience thermal runaway. To make it short, LFP batteries are less likely to catch on fire than NMC batteries.
This isn’t to say that if you install an NMC battery it is going to spontaneously combust. But, if an NMC battery experiences too much stress or is handled improperly, there’s a higher chance of things going awry. This is why it’s important to use a licensed, trusted installer for your battery to minimize any chances of things going wrong.
Upfront cost
Winner: NMC
NMC batteries tend to be just a little bit cheaper than LFP batteries. This mostly has to do with economies of scale - NMC batteries are more prevalent here in the U.S., so their prices are a bit lower.
Plus, LFP batteries are slightly bigger, so it may take some more labor to move and install them. The cabinets that hold LFP cells could also need more materials simply because of their bigger size.
The cost difference between NMC and LFPs is definitely more of a factor when it comes to larger-scale projects. For home solar, you can usually find both types of chemistry in the same ballpark.
Value
Winner: LFP
We did just say that NMC batteries cost less upfront, however, LFP batteries give you a little more bang for your buck.
It’s important to consider how much electricity you’re able to get out of your battery to truly determine what’s the best value, and in many cases, LFP batteries come out on top because of their longer lifespan.
The easiest way to explain this is with an example. Let’s compare the sonnenCore battery with the LG Chem Prime:
Table. Comparing sonnenCore and LG Chem Prime solar batteries
 sonnenCoreLG Chem Prime
ChemistryLFPNMC
Capacity10 kWh10 kWh
Cost (before installation)$9,500$7,000
Energy output during warranty period*58,000 kWh32,000 kWh
*Estimated amount of electricity the battery will discharge before the battery drops to 70% of its initial capacity
As you can see, you can get almost twice as much use from the LFP sonnenCore as you can from the NMC LG Chem Prime, so the extra money you'll spend upfront is worth it. Not only that, but you get some peace of mind knowing how safe LFPs are, all without having to sacrifice performance.
And the winner is…
Based on the overall value, we would recommend looking into LFP batteries for your solar storage system. Even though they might have a slightly higher price tag, LFP batteries last longer, have better safety ratings, and perform just as well as NMC batteries on most metrics.
But that’s not to say you should flat out avoid NMC batteries. NMC batteries still do a great job at storing solar energy, so if it’s easier for you to get your hands on one, by all means go with the NMC. You may also want to consider an NMC battery if you’re limited on how much space you have to install a battery.
  • avacadovich
    avacadovich Registered Users, Users Awaiting Email Confirmation Posts: 1
    Jenny, you should define your abbreviation the first time you use it.  Not everyone is conversant with NMC and LFP!  A word to the wise!
    Dave Angelini Solar Expert Posts: 7,127 ✭✭✭✭✭✭
    If you search the forum here, I think you will find us saying this, along with the NAZ store here in 2018.
    Never hurts to post this for posterity😉
