Jackery Explorer 5000
nschizzano
Registered Users Posts: 44 ✭✭
Anyone with a jackery explorer 5000 here? If so did you construct your own PV array? And what did you do? Seems series with about 400w panels is most suitable. What voltage did you end your string at? Thanks
Nope not me but I have set a few up. As for panels you need panels with enough MPPV to charge the max battery voltage plus some extra V for clouds/loss. You could use, for example, A string of (3) 200W panels that have a MPPV of 23 V wired in series. You could use (2) of the 400 watt panels that have a MPPV of 31V in series. Good Luck !"we go where power lines don't" Sierra Nevada mountain area
- 232 Forum & Website
