Schneider Cloud Server is Down
Cloud server down. Heard this from Schneider:
We are following up on your concern regarding the IS mobile application showing no data.
Please be advised that this is a known issue related to the Insight Cloud server, which affects Insight device firmware versions 1.17 and older. Our team is already aware of the issue, and this has been escalated internally for investigation and resolution.
At this time, cloud data may not be available until the issue is resolved. We will provide updates as soon as more information becomes available or once a fix is implemented.
We appreciate your patience and understanding. Please let us know if you have any additional questions or need further assistance.
Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 650ah LiFeP04 battery bank - 5 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
  • Wheelman55
    Wheelman55 Registered Users Posts: 281 ✭✭✭
    Back on line.
